Recently completed GTR that was a ground up rebuild
Electric power steering system completed
Fuel system upgrade on a 200sx
Custom surge tank and twin 044 mounts for an S14
Welded in half cage for a very neat S14 being built
R33 GTR specific power steering resiviour, these are great for big single conversions
Under car surge tank to suit twin 044 pumps
Custom S13 catch can that was done for a local drifter
Simple little 1.5L surge tank that sits behind the diff in the S13/R32/R33 and mounts a single 044 pump
Thanks Ryan.
At the moment I've got a couple of cars but nothing that's running. I don't have the time to do anything for myself at the moment so it gets pushed to the back.
The R33 has never beenade elligability for 2A. Duncan was trying to get them homologated but I believe racing evidence was difficult to find.
Custom made alloy strut brace up for grabs, was made up for an aristo but customer changed their mind.
Fabricated from 6061 3mm alloy plate, two U shaped halves welded together with a solid 3mm plate bottom. slight curve in the bar 5mm rise in the center, unwelded on the top side in the center to give a neat looking gap down the middle
Machined 6061 alloy circular ends welded to the ends.
Base plates made from 6061 which are being redone at the moment to suit a skyline R32 or R33.
Going for $330 inc gst and postage to anywhere in aus.
  • 1 month later...
Update before the end of the year with some of the smaller stuff weve been up to custom fuel cell and internal pump for a datsun 1600. post-20349-0-04172800-1355949712_thumb.jpg Polished surge tank and lift pump going into a GT3 lotus exige post-20349-0-44401600-1355949714_thumb.jpg R32 GTR alloy door trim post-20349-0-16278900-1355949713_thumb.jpg Polished breather tank for same GT3 lotus post-20349-0-29072700-1355949718_thumb.jpg 180SX front air dam post-20349-0-59608100-1355949719_thumb.jpg N14 pulsar steering coloum mounts post-20349-0-52565300-1355949721_thumb.jpg Supercar engine bay back from paint shop post-20349-0-29692800-1355949723_thumb.jpg
R32 GTR recently completed
Although it looks like a subtle car its rather serious
R34 GTR in for a comprehensive cage, rewire and some tidying up
R33 GTS-T roll cage and steering mounts thats just been completed
New oil surge tank ive been developing.
Will those baffles use foam like the mines ones or something else?
I wish i had even a tenth of the talent you have, all your work is amazing!
Will contact you soon in regards to getting a powersteer resevoir similair to the one you did in that r32 with the electric setup.
Edited by k_d
Thanks for the compliments.
It's only practice and patience.
Yeah they are designed to use foam similar to the mines ones but with people using E85 and having E85 in oil and what not I'm getting some better quality foam cut to fit them properly
Here is something ive been working on for some time. This is the 3rd one to be fabricated but the first Ive taken photos of.
Its an oil surge tank specific for the R33.
Basic principal is same as a Fuel system.
9L sump feeds an external scavenge pump
Scavenge stage of the pump is used to fill this tank
Main pressure stage draws from the bottom of the tank via a funnel and internal baffle system
Pressure stage provides engine oil pressure
obviously there has been alot of small things to test and change as the system was developed.
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
