Recently completed GTR that was a ground up rebuild
Electric power steering system completed
Fuel system upgrade on a 200sx
Custom surge tank and twin 044 mounts for an S14
Welded in half cage for a very neat S14 being built
R33 GTR specific power steering resiviour, these are great for big single conversions
Under car surge tank to suit twin 044 pumps
Custom S13 catch can that was done for a local drifter
Simple little 1.5L surge tank that sits behind the diff in the S13/R32/R33 and mounts a single 044 pump
Thanks Ryan.
At the moment I've got a couple of cars but nothing that's running. I don't have the time to do anything for myself at the moment so it gets pushed to the back.
The R33 has never beenade elligability for 2A. Duncan was trying to get them homologated but I believe racing evidence was difficult to find.
Custom made alloy strut brace up for grabs, was made up for an aristo but customer changed their mind.
Fabricated from 6061 3mm alloy plate, two U shaped halves welded together with a solid 3mm plate bottom. slight curve in the bar 5mm rise in the center, unwelded on the top side in the center to give a neat looking gap down the middle
Machined 6061 alloy circular ends welded to the ends.
Base plates made from 6061 which are being redone at the moment to suit a skyline R32 or R33.
Going for $330 inc gst and postage to anywhere in aus.
  • 1 month later...
Update before the end of the year with some of the smaller stuff weve been up to custom fuel cell and internal pump for a datsun 1600. post-20349-0-04172800-1355949712_thumb.jpg Polished surge tank and lift pump going into a GT3 lotus exige post-20349-0-44401600-1355949714_thumb.jpg R32 GTR alloy door trim post-20349-0-16278900-1355949713_thumb.jpg Polished breather tank for same GT3 lotus post-20349-0-29072700-1355949718_thumb.jpg 180SX front air dam post-20349-0-59608100-1355949719_thumb.jpg N14 pulsar steering coloum mounts post-20349-0-52565300-1355949721_thumb.jpg Supercar engine bay back from paint shop post-20349-0-29692800-1355949723_thumb.jpg
R32 GTR recently completed
Although it looks like a subtle car its rather serious
R34 GTR in for a comprehensive cage, rewire and some tidying up
R33 GTS-T roll cage and steering mounts thats just been completed
New oil surge tank ive been developing.
Will those baffles use foam like the mines ones or something else?
I wish i had even a tenth of the talent you have, all your work is amazing!
Will contact you soon in regards to getting a powersteer resevoir similair to the one you did in that r32 with the electric setup.
Edited by k_d
Thanks for the compliments.
It's only practice and patience.
Yeah they are designed to use foam similar to the mines ones but with people using E85 and having E85 in oil and what not I'm getting some better quality foam cut to fit them properly
Here is something ive been working on for some time. This is the 3rd one to be fabricated but the first Ive taken photos of.
Its an oil surge tank specific for the R33.
Basic principal is same as a Fuel system.
9L sump feeds an external scavenge pump
Scavenge stage of the pump is used to fill this tank
Main pressure stage draws from the bottom of the tank via a funnel and internal baffle system
Pressure stage provides engine oil pressure
obviously there has been alot of small things to test and change as the system was developed.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
