  • 3 weeks later...
Brad I'm still waiting for my surge tank that i paid for in May, you have told me that you have sent it on numerous times over the past couple of Months, and that I would get the tracking number the next day, i have given you more than a fair chance, i even had orgnaised a close friend that was in sydney on a Saturday to meet you to pick up my surge tank, you didnt answer your calls like you said you would. How would you like it if i had you complete work and not pay for months on end! You had no problems taking my money. Contact me. if anyone can get a hold of Brad can you get in touch with me.
My car is there now and is almost finished. Job got a lot bigger than first agreed and naturally timeframes extended by a few weeks which was totally expected.
The service I have received is sensational and the work on the car from both Brad and Dylan I could not be happier with.
Will post some pics of the work shortly.
  • Like 1
The work is obviously good, but seriously ripping off customers for his own gain is terrible! This needs to be addressed!
It would be interesting to see the amount of money that's been thrown at this guy.
That's fair enough... But that only shows that he is dismissing all the other problems in gain of trying to get new customers!
He has lied to so many customers using his wife & his very young daughter as a tool to get out of it all, which personally is the weakest form possible!
I have lost respect for this guy & I'm sure many others will agree with me!
  • Like 1
This. Well said.
I am now calling this guy multiple times a day. I have had absolutely no response. And if the outstanding parts and money aren't enough he still hasn't returned the key for my car. There is no spare.
If anyone would like a secondary phone number for Brad, PM me.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
