hey guys,
not sure if there is a thread already but there is going to be a cruise on this Saturday night the 17th DEC,
meeting at Bunnings car park Crossroads at 8PM
all details can be found here - http://www.nissansilvia.com/forums/index.php?showtopic=514636
cheers
D
A advertised night cruise through Nasho for a blend of modified cars at Christmas is asking for attention, thanks for the heads up, Ill keep well away from there.
Looks good!!:banana: madd way to end the year...
:laugh::rofl2: lolspec!! i checked that thread, no one sems to be goin from there and plus i heard they're doing their own shit cruise in the rain on sunday anyway
:unsure: WTF.... its a cruise, nice night out to Wollongong & a chance to see some nice cars... chilllax people!!!:spank: :spank:
Anyways, i hope to see afew people from SAU out if you can make it after the other Trackday @ Wakefield which looks awesome, spewing im working otherwise i'd be there for that too :action-smiley-069:
Did anyone go to this??
Heard it was a pretty big turn out
I actually went, took my old car, which I had to borrow off my mate :merli:
I usually don't go to these cruises, but I was bored so I gave it a go... Surprisingly, against everyone's belief and expectations every IMPORT driver was well behaved, no speeding or burnouts.
The only stupid burnout or engine revving I saw came from either Holden or Ford owners and them trying to drag everyone.. pfft.
i'm not sure about that, the R33 was doing quite a bit of revving and burnouts out of the car park, then at the right turn at the lights, I could hear it go nuts the whole way down, other than that, didn't see too much silly things, at the car park anyways.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
