hey guys,
not sure if there is a thread already but there is going to be a cruise on this Saturday night the 17th DEC,
meeting at Bunnings car park Crossroads at 8PM
all details can be found here - http://www.nissansilvia.com/forums/index.php?showtopic=514636
cheers
D
A advertised night cruise through Nasho for a blend of modified cars at Christmas is asking for attention, thanks for the heads up, Ill keep well away from there.
Looks good!!:banana: madd way to end the year...
:laugh::rofl2: lolspec!! i checked that thread, no one sems to be goin from there and plus i heard they're doing their own shit cruise in the rain on sunday anyway
:unsure: WTF.... its a cruise, nice night out to Wollongong & a chance to see some nice cars... chilllax people!!!:spank: :spank:
Anyways, i hope to see afew people from SAU out if you can make it after the other Trackday @ Wakefield which looks awesome, spewing im working otherwise i'd be there for that too :action-smiley-069:
Did anyone go to this??
Heard it was a pretty big turn out
I actually went, took my old car, which I had to borrow off my mate :merli:
I usually don't go to these cruises, but I was bored so I gave it a go... Surprisingly, against everyone's belief and expectations every IMPORT driver was well behaved, no speeding or burnouts.
The only stupid burnout or engine revving I saw came from either Holden or Ford owners and them trying to drag everyone.. pfft.
i'm not sure about that, the R33 was doing quite a bit of revving and burnouts out of the car park, then at the right turn at the lights, I could hear it go nuts the whole way down, other than that, didn't see too much silly things, at the car park anyways.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
