Ok guys, I couldn't search to see if this has been covered before or not since I was on my iPhone, but this blew my mind......
The rear seats on my c34 stagea are adjustable!!!!!!
Adjustable rear seats = mind blown.
Does anyone on here want to drive my car so I can sit in the rear seats?! :P
This just blew my mind!
That is all, now go on about your day as if nothing has happened....
https://www.sau.com.au/forums/topic/385757-stagea-rear-seats/
It's so amazing! It's standard on the c34 as well, but I didn't find out till today. After owning the car for 2 years! I sat in the back and I felt like a butt raped squirrell sitting that straight. So I pulled the lever while sitting and it went back! Boy was I amazed!
well since i got my tire changed yesterday and the dicks there threaded my bolts, my rim decided to say goodbye to my car and rolled away while driving....... so now i dont have rims on the rear. but i get to sit down in my awesome rear seats!
so its all good.
so its all good.
Hang on; you lost a wheel?
Any damage? I'm assuming they're paying to repair?
lost a wheel, but since i was running spacers, which they clearly saw. (as the r34 gtt rims wont clear my suspension due to such a shitty offset)
they threaded the nuts, and 3 of my bolts. so when i was driving the rest kind of undid themselves during my 3 hr drive, and when i hit 70kmh, i heard a rattle then my center cap with all 5 bolts flew out, and my rim incl tire followed........
luckily since i sacked my car and the rim was in the arches, it never fully dislodged, and just hung on by about 1-2mm on the bolts, giving me just enough time to pull over.
i then called them they came down and told me they didnt want to cover me because i had spacers on...... so the guy saw my shredded tire and told me he will be a good fellow and give me a new tyre the next day........ for the low fee of $50... i bought the tire brand new for $85!!!
so i will go there on monday and really turn his neck 180 degrees!
So note to self, never ever go to St George Tires.
Tyre shops and Rattle guns... They never mix.
I specify upfront; that if they use one to tighten the nuts, I will refuse to pay. I make them list it on their work order. I also make them list that there is no damage to the rims; particularly around the wheel nuts. I didn't pay $600 for 2pak paint; only to have some donkey destroy them.
Sounds like you were pretty lucky then; could've been much worse.confused.gif
  • 2 years later...
I thought they were adjuatable. Drove mine to adel from melb on wednesday night after pocking ot up amd remember they looked noce and layed back. Got home and showed the missus around it and pulled the seat down lever. When I pulled the seats back up they looked really straight. Looked everywhere for a button or lever then just resigned it to a lack of sleep. After reading this post, I had another look.. AHHH! There's the lever! Nice amd reclined! Man the japs are on to a lot of things awesome! Love my new stag
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
