hey guys
i have just installed an safc 2 into my 96 s2 r33 gtst i have followed the instruction manual from the net. Once i finished wiring , soldering and doing the initial set up i started the car up and noticed that i have 100% throttle, i have continually reseted the safc 2 and also jiggled the wirings but the 100 percentage still did not move , i have been told it must be the settings on the safc 2 itself and not a throttle sensor problem ,
any suggestions ?
https://www.sau.com.au/forums/topic/385797-safc-2-problem/
hey guys
any suggestions ?
Have you done the proper sensor calibration?
https://www.sau.com.au/forums/topic/385797-safc-2-problem/#findComment-6153814
yeh just tried to turn it on but the safc doesnt even start , pulled the thing (safc) apart and found out one of the soleniods or the small circle thing is sorta snapped off inside so the safc is pretty much useless , and so is the thread lol , freakin pissed but
https://www.sau.com.au/forums/topic/385797-safc-2-problem/#findComment-6153885
i dont know but i unplugged the safc 2 from the extended harness and drove down the road and went on limpo mode, found out the airflow wire was doing it so i connected the safc 2 again to avoid the car on limp mode but the safc itself isnt even turned on, the photo i attached shows the circle thing im holding has come off the circuit card , what should i do? i was thinking of getting another safc 2 or can an safc 1 with a harness clip fit to an safc 2 extended harness clip which is already wired in?
https://www.sau.com.au/forums/topic/385797-safc-2-problem/#findComment-6155243
  • 3 months later...
Well i just got another safc 2 from a fellow sau member And hooked It up to my existing extended harness which was already connected to my ecu, its still reading 100% throttle and i tried to look through the safc manual on throttle self learn procedure but its very vage .
So can some one (please) give me a step by step on how to do the throttle self learn sequence ?
The settings are on;
Hotwire - 1 / 1 - 1 / 1
6 cyl - arrow up
Anything else i need to set up ? Eg hi-lo throttle settings?
Any help sau
https://www.sau.com.au/forums/topic/385797-safc-2-problem/#findComment-6277838
Yeh i know but might aswell make this work till i get more funds for the next ecu , but i am positive about the wiring , all the wires are soldered in and i have been saving the settings but im pretty sure it might be that i havent done the self learning thing
https://www.sau.com.au/forums/topic/385797-safc-2-problem/#findComment-6279676
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
