Yo GOT BOOST, :headspin:
Watched your runs and they were mad. It looked like you were going great after the first 11.7 run. Gald we left when we did as the track got even more slippery as it started to rain. That last run of 11.5 was outstanding well done.
As you could see from my times the NEW ECU is on song and now for some dyno time and Nitto's then back to the track for some PB times.
I did a 13.4 untuned ECU (thanks Fane for the yahoo's), but what was important was the terminal speed of 108mph/175kph that has me the most excited. So back to the track. hope everyone gets down and has a run.
Paully are you going to have a run next week????
GTRRRR, great run dude nice 12.5 , shame you are selling the car and the drift damage sux.
FANE, thanks for the support, get your car there next week. :)
https://www.sau.com.au/forums/topic/38585-slicks/#findComment-783826
sean,
I don't know if you already do this but, if you wait till the last couple of orange lights with the clutch pushed in , when in gear, and mash the go pedal in one hit and as the revs jump to 7000 sidestep the clutch. This works a little better than holding the rev limiter because you get a smallish amount of boost built as the engine experiences light load from accellerating itself. Next step antilag ? :)
https://www.sau.com.au/forums/topic/38585-slicks/#findComment-785765
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
