Hi guys;
I was going through a traffic light at the normal speed limit and a car came flying past me from behind and the camera flashed! he was probably doing 80 in a 60 zone - Pretty sure we were right next to each other when the flash happened so my question is, I wouldn't be pinged by that fine would I? How do the camera's know which car was over the limit?
https://www.sau.com.au/forums/topic/386219-speed-camera-question/
Hi guys;
the exact same thing happened to me and i didn't get a fine that was 6-7 months ago now so wouldn't sweat ,not sure about how it pick which cars which
They know which lane triggered.
You won't get a fine. They most certainly will send out if more than one car is in the pic.
I mean take the cameras on Hoddle St, Dandenong Rd etc - Traffic 24x7 and the cameras go off like Christmas lights!
As above, sensor information is included with photo and if you request the photo it will actually mark in which lane you were speeding. Two pics are taken at intersection cameras and these show which car was going faster.
You should not worry - you were doing the right thing...their technology should differentiate accordingly but even if it fails to - just spend 10 minutes wring them a letter to contest the fine and you will definitely be in the clear - wait 1 month or so and you should know...don't worry...
this is true, however those camera's on hoddle are pretty much always faulty :rolleyes:
Since we are on the topic of speed/red light cameras and hoddle st... I see it happen alot where people get in the right lane to turn right, sitting on the sensor and then go f"k it, i'll go straight, get off the sensor and the camera obviously takes a shot as it thinks they are turning on a red... is what they are doing legal? or are you obliged to turn right?
differing opinions? seems like everyone is in agreement... nothing to worry about
Paranoid OP hear's what paranoid OP wants to hear :)
I think it's technically illegal to do that, because you're changing directions at an intersection and you almost always have to cross over a solid line to do this manouvre. But I don't think you'd get a camera fine for it if the camera went off. Reason being, is that red light cameras must take two photos for you to receive a fine: one at the first sensor when you cross the pedestrian lines into the intersection, and a second photo upon crossing the sensor at the middle/end of the intersection. The assumption is that people who willingly travel through the red will cross over both sensors, whilst those wanting to stop short of it and not completely cross the intersection will only get snapped once - behaviour they obviously want to promote. Saw a friend driving and put on their brakes in the wet once...they were carrying a heavy load and their tyres weren't fantastic, so they skidded to a stop in the middle of the intersection. Camera went off once, but no fine ever came of it.
did it once, camera went off... no fine :)
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
