With a decent rad set-up, it'll take ages to get hot. It's not a backwards step for a street car at all.
End of the day water cools better than air anyway. So on a 30 degree day, even if the water temp is 40 degrees it'll do a better job.
You show some data and i'll take my words back, but water will always cool MASSIVELY better than air. Get a decent size rad, decent sized core
Quite a few manu's from the factory use W2A, I'd take a guess mainly @ space saving vs performance given it would cost more, but hey, the Veyron uses it - can't be to shit! :)
The only disadvantages are weight, more complex installation and the cost. It wouldn't be simple and you would need to use decent parts & fittings for reliability where a A2A doesn't matter.
You'd also need to workout what motor & how much flow, vs the cooling etc.
Water cools better and has more heat capacity, need more heat capacity? add more water, or add more cooling.
If appropriately chosen gear is used it can work fantastically in any scenario, the main issue is the appropriate gear for the engine/turbo combination can often weigh so much it is not worth while, eg a track car.
For a street car if you don't mind adding 100kg of water I can imagine it cooling any system you can dream up, even with a undersized radiator it would take a long time to get heat soaked.
Edited by Rolls
W2A is a good option for a whole lot of reasons but you still need a decent radiator, thermo fan, good quality water pump and a good core.
I have installed a W2A system on a turbo diesel patrol and it is miles ahead of the pissy little A2A system in almost every way except complexity. And it is not that cheap by the time you buy decent silicon joiners for the air side and a good pump and radiator for the wet side (recommend a Bosch Cobra pump)and custom fab everything. Whatever you do don't let any of the eBay style merchants convince you that a little oil cooler sized radiator will work efficiently (unless you have a huge storage thank somewhere for additional water to act as a bigger soak).
Looked into a similar setup on a GTR and it just didn't stack up over A2A.
For about 1/10th of the weight of a water intercooler you could have a NOS intercooler spray and a 100 shot of NOS bottle.
The reason they are good for drag is peeps put ice and dry ice in the water intercooler, not really practical on street or track.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
