  • Replies 68
hi guys, i've been reading the stagea forums for a while after buying a silver m35 2 months ago, made the decision to buy it as the daily drive ever since i saw Craig's(jetwreck) black fat cow lol.
however, i have a supercharged 350z which (with big thanks) Craig and Alex installed for me, do you guys mind if i take her to the strip to see some numbers? hoping for somewhere in the 13s.
i can also ask to see if anyone from the Z club is interested too and make it a Stag v Z drag day haha. i think it will be a pretty even playing field and the FI nature of the Stags might even give you guys an upperhand in terms of modding for the drags.
black fat cow will be the car to beat i reckon
Nick imo your more than welcome!
We will have to line up the Nismo broad minded person's (350z and M35) and give em a go!.....might have to put the e-manage and injectors back in first! I think you'll be more than surprised....I recon you'll crack a 12 easy!........just watch your mirrors......like my wife says "your a slow starter but fast finisher Craigos!".....pfffft like she would remember!
P.S. Only guy I want to beat is Alex is his poofy Silver poverty pack! :P.....we will see how his car goes after this weekends install....turbo's going on his the glass bottom motor!
P.S.S. >>>>>>>goes out to garage to start the fat cows Jenny Craig weight loss program!ph34r.gif
Hey stop bagging out our VQ35DE...S and T! im sure there's motors with weaker bottom ends... the other guy with the supercharger Z got 13.5 at WSID, so thats what im aiming for i guess, hopefully autos are faster at the drags/minimizes driver errors.
so ur going all out to get into then 12s eh? maybe take out the spare tyre and boot linings etc to shed a few kilos in a week or money back from Jenny :blush: .
so far the nitto invos are great, not losing traction as much as before, and are soooooooo much quieter than the ku36s, I don't feel like im driving a friggin tank the whole time anymore :banana:
AND THE TREADS LOOK WICKED!
The way things are going, I'm not going to be going down the track - won't have a tune. But could wreck it for others by covering track with oil and conrods...ph34r.gif
I won't be able to make it for this, but you guys should have fun out there.
Just FYI, SAU-NSW had a private drag day a few months back (September 18th), and we'll be having another one this year on June 2nd.
Because we hire the track exclusively, we get a whole day's worth of runs instead of just a few hours, and later in the day you can literally go out and do as many consecutive runs as you want. Charlie (NXTIME on here) and another guy on a motorbike would not even bother going back to pick up their time-slips - they'd do a run and come straight back out, turn around after going under the tower, and line up again straight away!
I personally did 8 runs over the span of the day (with a best of 13.8) and Charlie and the guy on the bike must have done 20+ runs each...
Here's the wrap-up thread: http://www.skylinesaustralia.com/forums/topic/377530-saunsw-drag-day-wrap-up-thread/
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
