What is the best way to cut a hole near the washer bottle to run some IC piping up through?
Also how do you know for sure where to cut it?
It is for a Plazmaman plenum and Plazmaman IC piping on an ERC33.
https://www.sau.com.au/forums/topic/386626-cutting-hole-for-ic-piping/
Apparently cutting holes in the walls around washer bottle, or under battery tray in those "structural" areas are illegal and turn your car into a write off? I wanted to cut a small hole under the battery tray in that side wall where the tow hook is in my R32 to run piping through for a front facing plenum but a tuner / mechanic scared me off the idea... So im not so sure any more about cutting random holes
We used to get them all the time and knock them back on RWC's for it. You can get the cut approved by an engineer, and its easire than you think. Just have a chat to your nearest engineer and see what he says, it usually just involves stitching some flat plate around the area to give its stiffness back. Also, remember, measure twice, cut once and try to paint and line the exposed area to stop the steel rubbibg through your IC pipework and your car rusting.
what kind of place has an engineer? Are they special mechanics? We just call them Cert shops in NZ where a Low Volume Vehicle Certifier checks over your car and its modifications, eg suspension, exhaust, air bag suspension etc etc and if its at legal height and not a dodgy install he certifies it and puts a fancy little plate on your fire wall with the mods engraved. Is it the same here? I need to find out the ins and outs of this sorta stuff, its so much stricter in this country down.gif Cant build a 300kw car on your learners plates and legally drive it to school here
yep, in aus they have automotive gingerbeers, or certified inspection officers. You get it inspected, he signs it off, gives you a sheet of paper and if the mod warrants it, a blue plate.(in QLD anyway, unsure of other states)
  • 4 weeks later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
