Just got a profec b boost controller to keep boost in line thanks jez. The twin walbros will keep fuel in check. I'm lowering my power goals to around 230 as I want a internal gate turbo and more response then power but still enough to scare the missus haha.
  • Replies 117
Finally get to work on my car this weekend can't wait I'll fit the second fuel pump and the drivers door assembly window and lock then if I have time I'll slide the engine and g box in and do mounts
So got my bearings today for the sr they will go in on sat mid day. Picking the motor up sat morning from jase house it's a dirty sucker. I'll bolt the sr box up and drop it in I'm hoping with a few mates sat arvo then make up the mounts sat night then wire it's up sun ready to start I'm hoping it works but anyone that's worked on cars before to this level knows it never happens as planned. I'll take photos of the whole transplant.
Ok so iv done some reserch on the diff in my BMW tuns out it has a diff ratio of 4.44 and the m3 diff won't fit without dropping the whole cradle which I'm not going to do. Tge diff will make for some serious acceleration but I think it's going to suck on the freeway
I think u might b right there Blake that gearing is real tall
But as u said it will have great accel and will come on real nice
But high way diving round 100 will probably see revs round 3500-4000k which isn't ideal but bearable hahhaha
Ok so weekend not such a fail Tuesday has brung the best news out of this whole build and I'm excited to say the rb is back in action after 2 months of waiting on a reply a engineer said he will do it oh yeah now this build just got so much better rb25 BMW here we come in other words bend over and save yourself from being raped sr boys haha. Ok now some serious talk iv sourced a good condition rb25 with 155 across the board thanks andrew hopefully pick that up next week also luckily found a rb26 gear box which I will convert to rwd. So parts needed are loom, ecu and injectors. I plan on just cutting the flange off the rb sump and spinning it around 180 deg to fit in I'll make a forward facing plenum to further lower engine height and to tidy up the bay. Please don't say stock it best because I know but forward facing is just to make life easier. Hoping for updates soon I'll keep you posted
Well after being totally Fu ked around by the engineer who now cant renew his licence I'm screwed all Nissan is gone from this project but I'm still on the mission to make it turbo. But it will take a while so iv picked up a BMW m44 engine, box, loom, ecu and the rest for cheap so I can atleast get the car on the road. How here is the fun bit when I was talking to mitch the owner of Reno wreck and we where walking around looking at my motor options I stumbled across a m50 2.5l block with pistons and I thought hmm I could make some good power with that thing cast iron block comes STD with forged crank and rods and making 2.5l with a 84mm bore now iv done shit loads of reading about this motor and if I bore it out to 86 mm it would be in the 2.6l maybe closer to 2.7. So then I thought hmm what if I build this motor and slap a t67 on it I would easy see 350kw and the best bit I can actually engineer it no problems as a simple motor swap. So for now I'm putting in the little 4 banger 1.9l with a hole 92kw at the wheels and rego this car that has caused me so much grief and while I drive it around and enjoy it I'll build myself a monster that I will happily put down the quarter
Sounds like it could work out well. Excuse my ignorance, but when did the M44 and the M50 models come out? Was that e36 and 49?
The m44 came out 95+ in 318is and simular 3 serries. The m50 finished in 95 and replaced by the m52 which is a alloy block otherwise almost the same. My plan is to use to use a m52 head which features a vct type type of setup. I was going to turbo the m44 but let's face it there is nothing like capacity. My problem now is tuning and having to delete the afm so I'm thinking a g4 link or simular there is little to no info on a build like this and when there is they are yanks who talk out there ass. There are no listings for forged pistons acorrding to my local machine shop who can get everything but I'm thinking sr20 pistons will work same pin height and pin size. Iv got 3 stock pistons but need 3 more if I can't get them then I'll buy forged 86.5 to further push up those beloved cc
Mate you're asking for a huge headache doing that. Look at how BMW engines lean over on the exhaust side and think about where you're going to mount a turbo. As you said then ecu to control it and they also have quite high compression. It will be MUCH cheaper to put the rb engine in there.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
