what do you think of the rb26 miata mx5?
72 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hello a few buddies of mine started this project when I met them about 4 years ago ,a RB powered Miata mx5 !!!
at first we installed a rb25 neo motor had to do allot of r&d and we went 9.8 @ 143 in the 1/4 mile. while all that was going on we had been working on a rb26 building it from head.to toe! The car now has a RB26 fully built with a powerglide 2 speed gearbox,GM differential,custom made axles especially for this car from the DRIVE SHAFT SHOP AXLES,a pair of 26x10.5 Mickey Thompson full slicks , Garrett gt42-45R dual ballbearing turbo,c16 race fuel,26psi making over 800hp and 600+ ft.lbs.tq
let me know what you guys think!
this was our 9sec pass On the 5 speed manual gearbox (still had the rb25)
This was our first pass on the powerglide gearbox we didn't know how the car was going to react we wanted to see what it did so we could dial in the launch and everything else after
We were so happy the car did so great on the first pass!!!!! (RB26 set up )the car is capable of doing 8's , the 15th of January we are going to import face off here in SoCal we are definitely going 8's !!!!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/
  • Replies 48
Hmm thats a very interesting conversion. Its amazing how many different engines have gone into mx5s over the yrs. I personally would've gone a TT Lexus quad cam. But hey each to thier own :)
Edited by Raysboostin
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6173737
This is another video we went 10.1@91mph driver let off half a track and step on brakes at the end we were in a class for import face off we didn't wana get discualified lol Edited by nismorb25neo
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6178611
No I wish lol the motor wouldn't have let us put the radiator in ,we wanted the radiator to fit and not have to cut the crap out of the front so we cut 3" off the firewall to make it fit better,and it actually worked out very well and were very happy with the outcome! The 15th of this month is import face off here in SoCal,hopefully we can hit the 8's,were very excited about it! Its been a long journey to be where we are now alloy if sleepless nights and R%D. I will be posting up the videos for sure for you guys entertainment!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6181828
No I wish lol the motor wouldn't have let us put the radiator in ,we wanted the radiator to fit and not have to cut the crap out of the front so we cut 3" off the firewall to make it fit better,and it actually worked out very well and were very happy with the outcome! The 15th of this month is import face off here in SoCal,hopefully we can hit the 8's,were very excited about it! Its been a long journey to be where we are now allot of sleepless nights and R%D. I will be posting up the videos for sure for you guys entertainment!
https://www.sau.com.au/forums/topic/386948-rb26-miata-mx5/#findComment-6181984
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
