Firstly I apologies if this has been covered but either my search function sucks balls or I just can't find anything on the topic?
Ok so my exhaust is a 3" turbo back job but has a custom screamer pipe and a blocked bov for dose
Neither of these things appeal to me
The car has a td05 turbo gtr injectors FMIC and a few other goodies making about 210rwkw at 1bar
The reason I say this is I have 2 questions
Will a stock bov set up either still blocked or plumbed in properly be ok on these boost levels? am I going to loose any power or have more lag or response yadayada,
Looking for a slightly more legal and city friendly sound. I actually don't mind the flutter but yea anyway.
And the other question is what's the best way to plumb both of these things in properly? I know the screamer needs to enter the exhaust system before the cat.
The screamer makes sence to me but I'm not even sure if my blocked bov is a stock unit? Pick below.
Sorry I will also add that I have a limited understanding of the pipe work, how much would a shop slug me without being dicks to remove the screamer pipe and plumb it in?
Thanks in advance for the help and sorry if theirs a million threads already existing.
https://www.sau.com.au/forums/topic/387165-chasing-that-stock-sound/
  • Replies 75
Posted Images
Stock BOV it is . Just use some hose of that size, or source the original hard pipe from a wreck to connect the BOV outlet back to the turbo inlet. Depending on what needs to be done to your turbo inlet to hook that up, this should cost from not a lot to not a lot more.
Exhaust shop should be able to connect the screamer back into the dump at the bottom bend for not a lot. Almost beer money.
Oh, by the way, the stock BOV is the best thing to have on the car for response. And it will be perfectly fine at 1 bar boost.
Edited by GTSBoy
That is the stock BOV, they just whacked a cup over the end to seal it off. Take that off and get that line plumbed infront of your turbo, in your intake pipe. What ECU do you have btw? Do you have an AFM?
I would leave the BOV and get rid of the screamer. That one will get you into big shit.
you can buy a JJR bellmouth dump pipe for $180 which will fix your screamer problem, id rather do that than plumb in the screamer... the bellmouth works best on a stock sort of setup
reconnect the stock bov as its just capped off. buy the stock hoses and pipes from a wrecker. stock bov good to over 20psi no worries (1.5 bar)
Ok I'm going to fly my noob flag a little bit.
I buy the stock solid hose and that goes from my bov to.... Is their another blocked off hose point somewhere?
Also a new bellmouth dump pipe what size are they? Do I need a larger one?
can post a pic of the intake/turbo side of engine, as you say it has a TD05 so the piping may have been changed, if the stock intake pipe is still in place then there will be a port to plumb it back into.
if the TD05 turbo has the standard T25 flange setup them just buy the dump pipe as stated already, pic of screamer from turbo would help with advise aswell
agreed i forgot to take notice that you have a TD05, you may need to retain the custom dump unless your TD05 has the standard sort of dump pipe pattern.
please take a photo of your turbo and plumbing on that side and post.
Is that screamer just pressed into the WG outlet? Jeeezus Christ!
The dump and screamer are nasty enough that I would replace them rather than keep them. But yes, as above, it could just be joined back in and it would work*.
*by work I mean just as well as it does now, but without the shitful noise.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
