I have attached photo's of just a few of the parts I have available, please give me a call if you need any part of a R34 Im wrecking the entire car as it is a write off, my numbers 0400 508 382 call me anytime, if I don't answer leave a message, thanks.
https://www.sau.com.au/forums/topic/387344-r34-wrecking-have-heaps-of-parts/
drivers side "a" pillar trim that goes over the door opening , black its in the 5th pic ( black one top left corner of the pic.) how much inc postage to nsw 2259
EJD001 I think it might cost about 10-20 bucks for postage? so give me $40 and ill ship it asap
chilzz - whats a SMIC? if its a computer part I have all the computers from the car.
and sorry troy no headlights.
oh righto, yeah I have the stock intercooler. Im not sure what there worth, so make an offer, and then unless you live near geelong, include postage, and ill ship it straight away.
no tail lights, they were smashed, but I have the sun visors, were you after both? can send both to brisy for $60 including postage, ill give you a pic on sunday? (theres nothing wrong with them)
Yes very keen for both does it come with clip as well??
