Hello all,
I would like to share some pics of my new rims. They're 18x8 and made by Rays Engineering for Payton's Place. I bought them off the Yahoo Auctions in Japan thru J-Spec. J-Spec have also sourced me some Tein coil overs which should be here soon allowing me to put the car on its arse :)
The tyres are Hankook Ventus K104s (235/40/18f, 255/35/18r). The reason for the Hankooks goes a little like this; I was sold by the fact that they have the same traction rating (AA), same heat rating (A), and better wear rating (280 vs 220) when compared to the Michellin Pilot Sports. The best part is they're almost half the price!
Let me know what you think :D
https://www.sau.com.au/forums/topic/38737-new-wheels-are-on-the-car/
  • Replies 57
I hope you realise that the higher the treadwear rating (280 vs 220), the harder the tyre it is...
The Michelin Pilot Sports are a lot softer and stickier than the Hankooks... Yours will last longer but won't have the same level of grip.
Nice wheels! :)
Nice, what did you pay?
I dont really know because I havent made the final payment :) (long story). I'm expecting around the $1300 mark. Not bad for a brand new set of 18" Ray's :D
Hope you got lock nuts.
Yep, in fact would-be thieves would have to come ultra prepared ;)
I hope you realise that the higher the tread wear rating (280 vs. 220), the harder the tyre it is...
Nice wheels! :)
Yep, I'll pay that. But heres the deal, I had a V104K and a Pilot Sport side by side at the tyre shop. Everything about these 2 tyres was bloody similar. As I said, the traction and heat ratings are exactly the same, the tread patterns are bloody similar, and the review both tyres got in Motor (Dec 2003) is also bloody similar. That, teamed up with the fact that Michelin own 80% of Hankook, was enough for me to save the $200 odd per corner at the expense of negligible traction differences. And, as you pointed out, they'll last longer :D
you might be able to convince em to chuck the rims in the boot of the car if its still in japan. The new container we're packing should be ready ina few weeks, and then its shipping time again :D
which means all my shit will finally get here, then its widebody time :D:)
basically costs are:
cost to buy rims
cost to transport rims from seller to tokyo container packing place
taxes
then once it arrives here you pay a percentage of the total shipping cost which is broken up by how much you transported (dimensions and weight factors).
For example to ship my entire bodykit cost $400 (bodykit itslef cost $900) so for $1300 I got a brand spanking new not found in australia bodykit :D
Oh and not all Rays are expensive... :) if you know how to get em
nah i don't.... "we" was used meaning me n j-spec (coz I got some shit in there alongs with a few more stuff for a few of my friends etc). We're all good friends tho from a while back.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
