Hello all,
I would like to share some pics of my new rims. They're 18x8 and made by Rays Engineering for Payton's Place. I bought them off the Yahoo Auctions in Japan thru J-Spec. J-Spec have also sourced me some Tein coil overs which should be here soon allowing me to put the car on its arse :)
The tyres are Hankook Ventus K104s (235/40/18f, 255/35/18r). The reason for the Hankooks goes a little like this; I was sold by the fact that they have the same traction rating (AA), same heat rating (A), and better wear rating (280 vs 220) when compared to the Michellin Pilot Sports. The best part is they're almost half the price!
Let me know what you think :D
https://www.sau.com.au/forums/topic/38737-new-wheels-are-on-the-car/
  • Replies 57
I hope you realise that the higher the treadwear rating (280 vs 220), the harder the tyre it is...
The Michelin Pilot Sports are a lot softer and stickier than the Hankooks... Yours will last longer but won't have the same level of grip.
Nice wheels! :)
Nice, what did you pay?
I dont really know because I havent made the final payment :) (long story). I'm expecting around the $1300 mark. Not bad for a brand new set of 18" Ray's :D
Hope you got lock nuts.
Yep, in fact would-be thieves would have to come ultra prepared ;)
I hope you realise that the higher the tread wear rating (280 vs. 220), the harder the tyre it is...
Nice wheels! :)
Yep, I'll pay that. But heres the deal, I had a V104K and a Pilot Sport side by side at the tyre shop. Everything about these 2 tyres was bloody similar. As I said, the traction and heat ratings are exactly the same, the tread patterns are bloody similar, and the review both tyres got in Motor (Dec 2003) is also bloody similar. That, teamed up with the fact that Michelin own 80% of Hankook, was enough for me to save the $200 odd per corner at the expense of negligible traction differences. And, as you pointed out, they'll last longer :D
you might be able to convince em to chuck the rims in the boot of the car if its still in japan. The new container we're packing should be ready ina few weeks, and then its shipping time again :D
which means all my shit will finally get here, then its widebody time :D:)
basically costs are:
cost to buy rims
cost to transport rims from seller to tokyo container packing place
taxes
then once it arrives here you pay a percentage of the total shipping cost which is broken up by how much you transported (dimensions and weight factors).
For example to ship my entire bodykit cost $400 (bodykit itslef cost $900) so for $1300 I got a brand spanking new not found in australia bodykit :D
Oh and not all Rays are expensive... :) if you know how to get em
nah i don't.... "we" was used meaning me n j-spec (coz I got some shit in there alongs with a few more stuff for a few of my friends etc). We're all good friends tho from a while back.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
