hey guys, have a 32 gts and was looking at putting 32 gtst rear brakes on it. i got hold of some brakes, lines and rotors that came off a r31.
which i thought i killed 2 birds with 1 stone with getting 4 stud rotors.
BUT turns out the center of the rotor that goes over handbrake shoes is to deep and when wheel is tightend up fully it fowls the hub and
wont let wheels spin >_<
so just wondering what rotors i need to get? 32 gtst 1s and redrill to 4 stud? has anyone else ran into this issue?
should also add that front is already upgraded to 32 gtr calipers and rotors before people think im a total nut lol.
thanks in advance
beau
https://www.sau.com.au/forums/topic/387408-upgrading-brakes-need-help/
im thinking the best/easiest/cheapest upgrade for you would be to throw on R33 brake calipers/rotors/5stud hubs etc, that would open up a whole lot of wheel options for you as well, the 31 stuff taint the best especially the handbrake setup
sorry i musnt have made sence.
the only thing 31 is the actual rotor, standard 32 handbrake set up and 32 gtst calipers...
only reason i tried those rotors was cause they are 4 stud already.
not too keen on goin 5 stud as i have a set of LMGT4's on it now which i think look good!
thanks for your reply though dude.
cheers beau
The majority of the breaking effort is taken by the FRONT brakes. I can't see any great benefit in changing / upgrading the rear brakes.
Not quite...
With regards to the rear brakes, probably the biggest mistake people make is neglecting the rear because they beleive it does less work. Yes it's true that the rear 'axle' as a component does less of the overal vehicle braking, but it's also got substantially smaller hardware in which to do it with, so the actual 'brakes' themselves can often work nearly as hard as the front ones do. What can happen if you neglect the rear is that end starts to fade out slowly without you noticing, and it puts more pressure on the fronts, which causes them to fade, and people blame the front for a problem caused by the rear.
Yuh, the overall lesson is not to upgrade the rears on their own, but if you do a reasonable upgrade on the front then you should upgrade the rears as well if you can.
Even a smallish upgrade on the front will change the balance. I was convinced I had too much rear bias with standard R32 brakes. Same pads all around, which was probably the cause - I think OEm pads use a better coefficient pad material on the front. Anyway, put R33 calipers and discs on the front, so a small overall upgrade, but significantly changed the behaviour of the car. Wasn't so likely to lock a rear brake any more (especially the inner rear when late braking heavily into a corner). Much improved the balance in my estimation. If I were to use adaptors to push my front calipers out to use 324mm rotors, I'd start to worry about overdoing the bias change.
interesting replys guys, making me think i should get these rear brakes on, as i have 32gtr fronts and 32 gts rears.
that cant be good for the balance... :O
so back to 1st question has anyone upgraded 32 gts brakes and what to and how did they go about it???
cheers beau
Well, the answer to that question would have to be another question.....Wouldn't it be trivial to upgrade to GTSt brakes?
And yes, I know you said you've got some 4 stud wheels you want to keep, but that's a different problem. What are you running for front wheels?
Edited by GTSBoy
ummm any given brake set up? Ok... Im asking the question if these are good to use as I want to better my rear brakes, no need to be narky mate, im greatful for the help though... And my 1st question was what rotors can I use with the 4 stud gts rear hand brake set up, if 32 turbo rotors will fit, thats exactly what ill do as I have done that with the fronts... But I didnt want to go ahead and order them if they were going to turn out to deep like the ones iv just tried
Cheers
I wasn't being narky.
Have you looked at the DBA site's disc catalogue to see how compatible the R32 NA and turbo discs are (in terms of how they connect to the hub, hat depth, the size of the handbrake surface inside, as much as anything else, and ignoring the 5 stud/4stud thing)?
looked at r33 gts brakes? The non turbo r33 front brakes are basically the same size as the turbo r32 brakes so i'd imagine the 33 non turbo rears would be a good option, plus they're already 4 stud
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
