But when you look at Porsche>>>how many 911 models are their....and BMW and Audi......this is a missed Oppt....because in the 400 to 450 HP range there are only european cars....but no japanese cars and the model I am speaking of would sit that stop perfectly........just my...lonely two cents...LOL
B
Nissan/Renault will do whatever is profitable or cost effective for them over filling niches in a niche market
porsche don't make cheap econoboxes. Horses for courses
Cool vid nonetheless
Put simply, the GT-R has always had two turbos and four wheel drive.
If it was an R35 Skyline, there may be the option for a rear wheel, single turbo. But because we're talking about a GT-R, not a Skyline per se, it will always have two turbos and four wheel drive.
Guess we should tall all those C10, C110, C210 owners that they don't own a real GTR?
Oh wait, skylines didn't exist before 1989 ;)
I watched this a few months back. And just by the way the cars were lined up it was pretty obvious what the outcome was going to be.
Classic "V" formation. Looks pretty for the cameras. Like the do in Olympic swimming. lol
The GTR did great over the quarter mile, but we could quickly see the Italia was gaining on it. Another 100m and the Italia would have overtaken.
The same video magazine does in car lap comparisons at Leguna Seca - youtube it :)
The GTR is the best bang for buck package. They are so cheap OS compared to here they are the logical choice. You could nearly buy 2x GTRs in the USA for the cost of one here!
US MSRP $89,950 USD, used, 50-60k for a 2009 model.
Porsche 911 Turbo is only $139,000 USD new, compared to $400,000 k here.
You mean the 370z? If that's the case then the 370GT would be more approapriate wouldn't it?
He was (and I'm sure you've assumed) figuratively speaking. Nissan made a conscious decision to keep the 'Nissan GTR' as a seperate entity from the Skyline legacy, despite being a spiritual successor.
The 370Z has filled the void of the relevant Skyline GTS-T model at this time, since nissan has decided that V6's and not straight 6's are the way to go. In relative terms of performance and price compared to Skyline generations past, I'd say it's about a par.
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
