i ws just on the hypergear website and they start rebuilds at around 400 and thats all bearing and gaskets and thats if they dont need to replace any broken parts
is that a good price or does someone do it better then 400
  • Replies 40
yea thats what i thought and i can find a few bolt on ones off ebay for 400 but i really dont know the item and im unsure of the quality and reliability of it and how much to you think a hypergear fi-flow turbo would cost because im very keen to upgread and i wouldnt mind a nice 250kw or more but its my day to day car and not have the money to upgrade the injectors ecu afm and turbo at this point but if its almost the same price to hi-flow it i may aswell do that
also can i run a hiflowed turbo with stock injectors ecu and fuel put and afm and just run stock boost??
Or for a little bit more you can get an atr43 to suit 250kw or 300 depending on your goals. I've got my atr43 ss1 running 7psi so there isn't much reason you can't modify slowly, just be very careful about what you do in what order, I cracked a piston by taking too long to get it all tuned. But I did make 230kw with a cracked piston.
Im still pretty new on this site, let me answer this one lol
Option 1 - upgraded turbo = Tune, do u have a aftermarket ecu, if not ur up for about $5000+ (new turbo, ecu and tune)
How'd i do ?
You failed miserably unfortunately..
No way a new turbo, ecu + tune would cost this much.
Maybe if you went top of the line everything which he doesn't want to do.
Turbo = $900-1000
ECU = $600 - $1600
Tune = $500 - $800
Total = $3400 for something like
Power FC, 250-270kw hypergear turbo, tune
Total = $2000 for something like
Nistune ECU, Hypergear turbo 230kw + tune = 220kw max with stock injectors
Edited by Kasko
Turbo = $900-1000
ECU = $600 - $1600
Tune = $500 - $800
I dont see that i did, $1500 isnt much. If i was to be taking the next step, id be spending a lil more than $1000 on a new turbo
The HG turbo needs to magic itself onto the car for it to only cost $800-1000.
Its the hidden extras, like intake pipes, exhaust mods, injectors, AFM's, oil/water lines, stud replacement etc that some turbos require that is a hidden cost to upgrading.
Buying the parts is the easy part.
Everything costs money unless you bolt a stock one on. Plus good turbos can be had from 750 (kando) then your usual mods same as hypergear. Also is there oil in the dump all turbos have some shaft play no matter how new.
Which HG turbo? A simple rebuild/hiflow yes other HG turbos no. Don't forget labour.
Getting back to the OP I am still not convinced his turbo has anything wrong with it since it still makes boost so the best thing is to correctly diagnose what is happening before buying any parts.
ps. my daily driver has had a whole lot more than $1k spent on turbos over the years...like most SAU'ers.
^ my simple turbo replacement turned into a 10k rebuild pretty quickly lol.
quick question im looking at a really cheap r34 turbo with no nosie and no shaft play and lie $150 mates rates :) i was just wondering how much shit can it handle because im going to go the road of hiflowing my r33 turbo
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
