i ws just on the hypergear website and they start rebuilds at around 400 and thats all bearing and gaskets and thats if they dont need to replace any broken parts
is that a good price or does someone do it better then 400
  • Replies 40
yea thats what i thought and i can find a few bolt on ones off ebay for 400 but i really dont know the item and im unsure of the quality and reliability of it and how much to you think a hypergear fi-flow turbo would cost because im very keen to upgread and i wouldnt mind a nice 250kw or more but its my day to day car and not have the money to upgrade the injectors ecu afm and turbo at this point but if its almost the same price to hi-flow it i may aswell do that
also can i run a hiflowed turbo with stock injectors ecu and fuel put and afm and just run stock boost??
Or for a little bit more you can get an atr43 to suit 250kw or 300 depending on your goals. I've got my atr43 ss1 running 7psi so there isn't much reason you can't modify slowly, just be very careful about what you do in what order, I cracked a piston by taking too long to get it all tuned. But I did make 230kw with a cracked piston.
Im still pretty new on this site, let me answer this one lol
Option 1 - upgraded turbo = Tune, do u have a aftermarket ecu, if not ur up for about $5000+ (new turbo, ecu and tune)
How'd i do ?
You failed miserably unfortunately..
No way a new turbo, ecu + tune would cost this much.
Maybe if you went top of the line everything which he doesn't want to do.
Turbo = $900-1000
ECU = $600 - $1600
Tune = $500 - $800
Total = $3400 for something like
Power FC, 250-270kw hypergear turbo, tune
Total = $2000 for something like
Nistune ECU, Hypergear turbo 230kw + tune = 220kw max with stock injectors
Edited by Kasko
Turbo = $900-1000
ECU = $600 - $1600
Tune = $500 - $800
I dont see that i did, $1500 isnt much. If i was to be taking the next step, id be spending a lil more than $1000 on a new turbo
The HG turbo needs to magic itself onto the car for it to only cost $800-1000.
Its the hidden extras, like intake pipes, exhaust mods, injectors, AFM's, oil/water lines, stud replacement etc that some turbos require that is a hidden cost to upgrading.
Buying the parts is the easy part.
Everything costs money unless you bolt a stock one on. Plus good turbos can be had from 750 (kando) then your usual mods same as hypergear. Also is there oil in the dump all turbos have some shaft play no matter how new.
Which HG turbo? A simple rebuild/hiflow yes other HG turbos no. Don't forget labour.
Getting back to the OP I am still not convinced his turbo has anything wrong with it since it still makes boost so the best thing is to correctly diagnose what is happening before buying any parts.
ps. my daily driver has had a whole lot more than $1k spent on turbos over the years...like most SAU'ers.
^ my simple turbo replacement turned into a 10k rebuild pretty quickly lol.
quick question im looking at a really cheap r34 turbo with no nosie and no shaft play and lie $150 mates rates :) i was just wondering how much shit can it handle because im going to go the road of hiflowing my r33 turbo
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
