Tv Coverage For Sau Vic Tri Club Drag Challenge
Massive news!!! Channel 31 Automotive Program " MY DRIVE" is going to do a feature on our Tri Club Drag Day.
Presenter Adam Tonkin is keen to cover all the action of the day!
Including footage of the Cruise there, the Racing, the Show n Shine and interviews with some of the owners of the cars, so get on board, clean those cars, enter the drags or the Show N Shine or just make sure you get your name down to spectate.
This will be a huge day.
Below are the links to My Drive, jump on Facebook click on 'like' and support this great show.
Website : http://www.mydrivemedia.com.au
Facebook : https://www.facebook.com/pages/My-Drive/179002238779472
Go check out the members thread with more details!!!!!
Link - http://www.skylinesaustralia.com/forums/topic/383927-tri-club-drag-challenge-sun-feb-12th-2012/page__pid__6183835__st__20#entry6183835
Maybe if I had enough info that would make me interested enough to want to go it would be, but all I know is there is an event some where doing some thing and channel 31 will be there, not enough to get me interested.
When i find something that interests me i will join, but whrn you have to go through a heap of bullshit just to get info on a single event and there is no other info on any event for the year let alone the next couple of months why would i bother?
It's the 22nd of January, people are on holidays.
Motorsport dates were only sent out from other clubs that we work around in very late Dec/Early Jan. Until they come out the overall calendar cannot be done etc.
If you don't like it - that's fine. Don't need to broken record about it.
Broken record about it? Care to point out where in this thread someone has mentioned that dates and details have not been finalised yet for 2012 so there is no other information available?
Thats all that needed to be said, instead the general consensus is to just pay the money to find out.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
