Starting gathering parts for the cooling system overhaul I'm doing to my drift car atm. I'm ditching the clutch fan set up mainly due to the fact I just don't have the room to fit all the parts required with out trimming something to make it fit.
Now I plan on running a tabata alloy core with an alloy shroud made up to space thermo and mount then too.am I beyer off running one large 16 inch spal fan in pull configuration or two 12 inch spal fans side by side also in pull mode?
I also plan on running a header/swirl put set up. Does any one have a diagram to correctly hook this up and what radiator cap I should be using on both the header tank and the rad itself?
Hey bud in regards to the twin 12" or single 16" question. The twin 12's will cover more surface area if you do the maths. Twin 12's cover 226.08 square inches, whilst the single 16 covers 200.96 square inches.
Running with this. If you can fit a single 18" it covers 254.34 square inches. Which would be the better of the 3.
Personally if you can fit the single 18" i'd be going with that. Simplicity is always better :) Hope this helps :)
  • Like 1
Id set it up on a 2 speed switch thing, so when its under temp it just slowly makes a breeze so you have a little airflow plus it uses hardly any current on low speed and will be quiet. Unsure if you need a special fan for low speed but with dc power i dont think so?? Thats just what id do thumbsup.gif
Simon, Im upgrading my twin 12inch Ebay fans to one 16inch Spal fan.
Make sure you get the 3000cfm one. Its a bit exxy but its well worth the money.
As for the header tank setup, just use a blanking cap for the radiator and a Nismo cap on the header tank.
Has anybody looked at venting the head water jackets in order to reduce localized boiling above the exhaust side of the chamber? I've tuned a high comp ls1 with this method of cooling and we were able to get the timing back up to around 22degrees (from16-17) and we gained about 25rwkw. It must be a problem with the length of the rb blocks.
The other gain is a lower coolant pressure which May reduce pumping losses.
would anyone see a problem with doing away with the rad cap on the radiator all together? for one its not going to be needed and secondly i can weld a nipple on the top tank in an elevated spot for the feed to the swirl pot anyway.
Simon, I intend on using a swirl pot as well, but I'll keep the radiator cap on the radiator for ease of filling most of the system as well as having a cap on the pot.
In this method, apparently the cap on the pot is to be of slightly higher release pressure than the rad cap.
Has anyone tried these ones from eBay?? they're stupidly cheap for 2750cfm! That could mean they aren't that great but much cheaper than the SPAL one to at least try.
NOTE: I see that the SPAL 16" Extreme one has the following warnings, not sure about the ebay one?
"The fan motor is not sealed and should not be used in the following conditions. 1. High dust, dirt, and/or wet environments. 2. Unusually high ambient temperatures (exceeding 176 degrees F). 3. extended/continuous modes of operation exceeding one hour in duration."
Maybe even 2x 12" ones as it appears they are rated to 1650cfm each. Seems to be basically the same as the rating of the SPAL 12" High Performance.
Don't know, that's what I'm asking.. hell, I may even consider using one if they are any good :) Might even be worth it for replacing the A/C one on the front?
I just had a very quick search but couldn't see any reviews..
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
