Guest Robo's
I just spent 2 hours on the dyno and finished up with 215rwkw on 13psi with the standard turbo on a Dyno Dynamics dyno run in Shootout mode. This is previously up from 187rwkw, but with the inclusion of the INTERCOOLERGUYS fmic and an exhaust cam gear, it made an extra 28rwkw. Im a happy man. Power is much stronger, especially top end.
Overall i had 16 runs on the dyno, walking in with 210-213rwkw but with a few missfires. I tried to tune out with the SAFC but to no avail. I wound down the boost to 9-10psi and was pushing around 198-200, with a nice steady climb with no missfires. So we figured, how do i run a nice clean run with higher boost, but with no missfires. I believed the extra boost was blowing out the spark. So i pulled out the plugs and gapped them from 0.8 to 0.7. Immediately at high boost there where no missfires and was getting 215rwkw on 13.3psi. Boosted it upto 14.5psi and it made 216rwkw, but midrange was lacking, so decided too back it off.
The intercooler looks great and fitted without too many dramas. Not once did the intercooler get hot during the 16 runs. A pleasure to have such a nice intercooler fitted and the performance is just great.
https://www.sau.com.au/forums/topic/38849-r33-fmic-results-215rwkw/
  • Replies 46
Holly crap you are running 13psi on the standard turbo? That sould last a few weeks at best :P I'm impressed that with the standard turbo you made 200rwkw's with 10psi!!! That seems very odd, I have a good hi-flow turbo and it is making 223rwkw's on 14psi and I have all the right gear with the exception of cam gears! Anyway stick the chart up when you have a chance.
Stop kidding yourself.
Robo's, that's an awesome result, mate. Well done! What plugs are you using, who is your tuner and how much was the cam gear/what type is it?
Adrian
Guest Robo's
Adrian
Im using Bosch Copper plugs 7 something code, maybe platnums might be better at higher boost, i dont know. Im the tuner, SAFC's aint the hardest to tune. Cam gear was from Ice performance, nothing special, just a modded standard unit, doesnt even have degrees on it, we had to try and work it out by eye.
May I suggest some BCPR7ES-11 gapped to 0.7 - 0.8mm for your next set. Leave the platinums to the people with more money than sense. :P
Very good result. Would be interested to see the dyno chart before and after to see whether you lost any power early on or through the midrange.
Adrian
Then you have the right plugs :cheers:
lol...
I've been racing on 1.0bar plus the nitrous for 3 months and 1.0bar for the year before that. The point is, there is NO hard and fast rule regarding when a std ceramic wheel turbo will fail. Just guidelines.
Adrian
shootout mode tries to make up for different losses on the dyno ...
the good tuners i know of don't use it
MSPEC - Ben doesn't use shootout mode, our dynos are non beefed up etc..
my 270kw would be closer to 300 on shootout mode...
dont know where u got dreamer mode from. Shoot out mode is shoot out mode, normal mode is normal mode, aslong as u say which mode ur hp/kw figure was achieved in then theres no dramas really, people understand. Im with 2rismo on the turbo issue. Many people say different things. Ive been running 13psi on my standard r33 gtst turbo for over 10 months now with no ceramic wheel trouble(knock on wood). Any way that dyno result is very good matey. Congratulations there, the car did well.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
