  • Replies 51
Ive been reading about the adaptronic ECU. It doesn't say much about knock control, but you do have a headphone socket which you can plug in headphones to listen to knock with. It looks pretty awesome, it can do everything I need it to and because Ive got a HG turbo, I get it cheaper.
yeah plus it has the built in MAP, so you dont need to buy one seperatly like LINK..Its an awesome unit, HG uses one now too..
Shoot them a message at Adaptronic, U will get a quick reply :thumbsup: .
Probably the only downfall of the ADptronic is it runs wasted spark config for 6 cylinders, the Link has full sequential but I dont think it matters enough to warrant concern..
@ full price I would be tempted to go link but at HGs budget price its a winner..
Their website didn't really say anything about that. Doesn't matter anyway, I really doubt the wasted spark is going to half the life span of my coils. Its not like you run out of spark, its generally heat and age that kills them(I got brand new OEM coils).
Does that mean with this ECU, you can run 3 coils to run cylinders?
does anyone have or had anything to do with the 'Display Link'... bottom of page
http://www.linkecu.com/products/engine-management/Wire-In/g4wireinfolder/g4storm
Is it just a display or does it work like the PFC commander where you can tinker with settings?
Sweet Andy thanks for the heads up mate :thumbsup:
Hahaha well i did offer tho :whistling: hope i get it back today keen as hell to drive it even to catch a wiff of the exhaust now lol
They should be into this arvo Mick.
No takers on the porridge but everyone thanks you for the offer. :yucky:
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
