Hey i have done a search without alot of success.
I read in another thread sydneykid and Roy talking about installing standard RB26 cams into an RB20.
I just wanted to know more about it. who has done it. what changes to the head are necessary and what sort of gains seen from such a modification.
any info would be great.
Cheers!
https://www.sau.com.au/forums/topic/38857-rb26-camshafts-in-rb20/
  • Replies 285
1. who has done it
2. what changes to the head are necessary
3. what sort of gains seen from such a modification.
Hi Benny,
1. We have, 4 so far
2. None
3. Very much depends on what else you have done. But from what we have seen, you will get;
A. earlier boost build
B. faster throttle response
C. about 15 rwkw increase in the average power from 4,000 rpm to 7,000 rpm
D. about 10 rwkw increase in max power
If you are on a budget and can do it yourself it is very worthwhile. If you can't DIY then you may well be better off spending a few hundred extra on used aftermarket cams, as the fitting cost will be the same. As Autobarn suggested, there are a few HKS 264's around that are a step up from standard RB26 cams
Hope that helps
Thanks sydneykid.
hmmm well im always keen to try it myself. however i have never installed cams before. but it hasnt stoped me from doing everything else to my car :)
ill have to read up on it first. any advice?
is there a large price difference between step 1 HKS and GTR cams?
Thanks sydneykid.
Hi Benny, since used pairs of standard GTR cams are pretty common, I wouldn't pay more than $300. Used HKS (or any other Japanese brand name) cams seem to go for around $800 for the pair.
I am also keen on doing this,
SK - have you noticed any differance between R32/33/34 GTR cams? each one seems to come out with differant torque from the factory, just wondering if this is cam related or something else?
Seems like a really good mod, I assume there are further gains to be had with adjsutable cam pulleys as well? Any setting you can recommend to try?
Chris
Hi Chris, I haven't seen any difference between R32 and R33 GTR cams. The R34 exhaust cam has slightly different lobe centres, but it is pretty minor, most likely for emmissions anyway. Adjustable camshaft pulleys are worthwhile, if they fit your budget. I usually start at 2 degrees advanced on the inlet and 4 degrees retarded on the exhaust.
Hope that helps
Cheers, now just need to find a set and I'll be right! I will get some cam gears as well to optimise the whole setup
Thanks for the info, those pulley settings seem to be what everyone ends up at with RB26's, would those settings still apply for RB20? I guess the best test will be to install them and have a play on the dyno to see whats best, but I guess they will be a good starting point
Chris
thanks for the info Sydney kid, i am just getting a pair of adjustable cam gears, but i think i will add a pair of GTR cams to the trolley and see what results i get.
for everyone interested i will post the results before and after so we can see the true difference.
Oh and any advice when installing them?
Anyone know what the difference in specs between the RB20 and the RB26 cams are. Im guessing the RB26 have a longer duration as the HKS would but maybe not as much???
Cam timing is pretty much the same (240) but the lift on the standard RB26 cams is much higher (8.6 mm vs 7.8 mm). So you don't loose a lot down low, but the extra lift is great all through the rpm range. Most brands of aftermarket 264's are around 9.2 mm lift and, depending on the condition of the hydraulic lifters, this can be a problem. Plus you loose a bit down low because of the longer duration.
The standard RB26 camshafts into RB20's is a real good, cheap upgrade.
Whats the go with hydraulic lifters if your current ones are a bit tired. I have been given a price to service a head, lifters and all, but what is involved?
Ive got the cams, valvesprings and cam gears to go in, but if you have a slightly noisy lifter on startup... im imagining its time to do something about the lifters at the same time as the GTR cams go in. ... What started out a s a cheap/budget upgrade to try and fill the lungs of the TD06 a little earlier is slowly turning into a pricey build.
hmmm thats what i was afraid of roy, something simple and cheap(ish) getting all nasty on me!
have you done the cam instalation yourself? how difficult is it. the only thing im worried about is setting everything in alignment - top dead centre or whatever. i dont want to make a mess of things when i get it all going.
To take the head off and instalibng the cams isnt a real drama, doing it with the head in place holds a few challenges which means i may not be able to do it myslef...
plus with my new accomodationin i no longer have a suitable place to work on my car. The compression test on my engine next week, and a few things falling into place the next 24hrs will play a big role in whether i bother with my current engine, or start with a blank canvas.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
