I'm with Bob buy them. It is inevitable that coils on a neo will fail.
I am not usually a fan of buying parts just in case but there is almost no downside in buying stock coils for that price. Make sure you buy coils for an R34GT-t / neo RB25DET not the R33 in that Ebay advert.
Alternatively buy a can of crc urethane seal coat and give the coils a good even spray it will keep you going for a good while in most cases.
Definitely get a new fuel pump - Deatschwerks, Denso, Nismo, Bosch 044 and wire it directly for full voltage (with a relay - tutorials on this site) and change your fuel filter. Do you have a high flow panel filter? Whatever air filter you use check to see if it needs replacing.
I reckon I'll do my fuel pump before I get the Nistune. Which one is regarded to be the best?
The Walbro GSS-342 seems popular, but I've read good things about the Nismo and Deatschwerks to!
The walbro's are good (If you get a legit one) but only up to around 20 psi, for boost above that I would recommend either of the other pumps. What are your power goals?
Hmm, sounds like the Walbro would be suitable - I'm not looking to set the world alight...
I got the deatschwerks, hardly breaks the bank at around $215 delivered, and small like the walbro
cheers
darren
my GSS342 is not to noisy, makes a bit of a buzz from time to time, i put rubber inserts in my cradle to stop vibration and noise(R33 Skyline).
i have a few mods planned for the year for my s2 RS4S.
walbro GSS342
nismo injectors
splitfire coilpacks
HPI FMIC
z32 AFM
TD06H-20G (internally gated version with replacable actuator springs - not chasing to much power)
tomei oversize metal headgasket - so i can run 16-18 psi through the neo.
ECU - probably a nistune, wasnt real happy with my powerFC.
i think that should make me a tidy 250awkw without pushing the engine to hard.
Edited by OMY31T
Cheers thanks for the info.....Yeah I currently have a flat spot at 5000rpm thinking its the coils tried taping them up as well as a high temp sealant ...with no change....I just don't want to get the car on the dyno and something like that fail and have to get it re tuned later........Change spark plugs recently and re gaped them to
I've got a pod filter and in the proces of making a cold air box for it.....
Thanks again ....
Flat spot is the tune. Cool packs break down. Of you can get new OEM cheap, do it now, has to be done at somepoint and means you aren't risking a tuning session.
Pumps: nismo or bosch
Cat: got a highflow item?
Ebc: yes, gizmo are good value.
Air filter: new highflow is $50, check yours.
O2 sensor? Has it been replaced? Dunno if your tuner will touch closed loop anyway.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
