Hmmmm. My mistake. I was going off NDSOC club criteria, which allows a few non-marque cars including GTR's, although GTSt's are all excluded......interesting that all 911's are included though.
Here is the MSCA current competition page for Vic.
http://www.cm510.com/msca/
NRB, while your putting new pads in, make sure you bleed the brake fluid, or even better, just replace it all with something like Motul DOT 5.1. Brake bleeding is not hard.
I have seen that a couple of times Geoff, I think it must be the old "GTR's were sold here" rubbish. After all it was only R32 GTR's, but they seem to ignore that and accept R33 GTR's and R34 GTR's as well. Snobbery keeps the "poor man's" GTST out though. I just enter those sorts of events as;
Make = Nissan
Model = Skyline R32
Don't mention GTR or GTST, they just assume it's a GTR and you are in.
SydneyKid - Ben is now using Bridgestone RE55's and he swears by them. He claims they give him at least a second over anything else he's used before.
Is he still running those slick tyre spring rates, 700 lbs in the front and 500 lbs in the rear?
I definately agree with that....but on the down side they're dead in literally 20 laps. Velllllly soft tyres. We ran em at Dutton Rally last year, took a second off our dunlop formula r times but they were showing canvas after the 20 events
Yes, even the GTS was listed as a GTR on the timesheets. Made it hard to determine who was doing what lap time.
I was happy enough though to do faster times than one of the 968cs cars on semi comp rubber with Targa spec preparation. the owner was parke 2 bays away and was shocked at the acceleration I had on standard computer. Pity about the limiter though. PFC to the rescue in 2 pay days :D
Maserati club page for those interested http://www.maserati.org.au/Quick_access.htm
no times yet.
I honestly don't know sorry. But I'm guessing you also don't know about the new wing then either Sydneykid. He says this has made a big difference as well!
I guess in a 4WD you don't really need as much pitch.
Also if you are using the springs to increase the roll stiffness rather than sway bars you will end up with a very stiff setup. Just look at the GTP cars, I am not sure now but previously you weren't allowed to change the sway bars so they were all sprung to the shiznit
It's easy NRB, get the corner speed up and you won't need to use the brakes so much.  We use DBA slotted rotors with Hawke pads in the Blue compound, still able to lock the wheels at the end of a 12 lapper.  Tyres are the limit of our braking not the brakes themselves.
You gotta get out there and get the adrenalin happening, it's good for the soul.
The last track day I ran RB74 fronts and Comp2 rears. Unfortunately I also had crappy "compliance" fluid, DOT4 I think. Since then I've replaced my fluid with Motul DOT5.1 and I've got some Galfer front pads for track days. I found with the crud fluid I could only string together 2 lapsbefore fade set in. I wish R32 brakes were bigger (mine's non VSpec). I'm also running a lot more power since that day!
Already done - see above. Thanks for advice though!
Sydney - the spring rates are in excess of 700lb fr / 500lb rear. How does this tie in with "the whiteline philosophy", ie dont use greater than 250lb rears even on a race car
Hi ben, as Gojira said, GTR's don't need to be as compliant in the rear as GTST's because of the 4wd. We have the same problem with production cars where we can't change the stabiliser bars or the anti dive or anti squat geometry, so we have to run mega spring rates. Plus we can't get enough positive caster under the regs and too much negative camber means it won't stop. For example we have an Integra with 1,700 lbs per inch rear springs. On the Improved Production Civic we run 700 lbs per inch rear springs, because we have changed the stabiliser bars and the suspension geometry plus it runs a lot of caster.
The mega spring rate philosophy is certainly not our preferred option. With similar tyres, the corner speed of the Improved Production car is much higher than the Production car but we have no choice under the regulations. Even the V8Dinosaur runs lower spring rates, despite weighing 30% more, than the Integra.
Hope that clarifies
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must me missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
