Hey guys..
havent had this car for long and only noticed that, once warmed up, the needle is 'sitting' on 2/3 up towards H!
I must of did a 2 hr drive back home when i first realised and seemed fine.. continues to be fine now
the car is completely standard bar frount mount and exhaust
I've already drained old coolant and refilled with new, checked and replaced radiator cap and thermostat.
im not sure what else i may be able to do?
been searching around i cant seem to find anything about it?
https://www.sau.com.au/forums/topic/389071-overheating/
If its overheating while driving ie: sitting on the highway at 100 --- I would be checking the radiator for blockages.
best way to do this (as far as i know) is to remove the radiator, boil the kettle, rad cap on , lay it down flat and poor the boiling water into it.
When its full, place your hand on the fins and move it all around feeling for areas that are cold.
When i did this with mine it was really easy to pick up,, i had a large area that was blocked.
If its overheating when sitting in traffic jams, then look at your viscous fan clutch.
google has plenty of advice about how it should operate and how to test it.
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6201290
So your saying that it gave you the same reading after you changed the thermostat, did a flush, new coolant and thermostat?
If it did, then as mentioned it can only be one of two things, dodgy temp sensor or blocked radiator.
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6201426
Yes use a consult cable ASAP. Assuming the stock gauge is correct, any movement upwards means your temp must be at least 110C and you're about to cook your motor. I've had my temp (reported by consult) as high as 104C and the gauge still said halfway.
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6205449
After it's been warmed up, whether i'd be sitting in traffic or on highways at 110, the gauge would read the same or close enough.
After all the above where changed and replaced it remains the same. It did however go very close to the line below H after a long drive from City to Penrith and back last night but dropped shortly after, while still travelling at the same speed :/ ?
I havent had the chance yet to try the temp sensor and radiator but will do this weekend if possible. I dont have a consult cable so i might just take it down to the mechanic to check this asap.
Cheers for the info guys i'll provide an update
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6205991
so i haven't yet been able to take it to the workshop to get it checked out as yet due to work and other commitments...
i did just come back from the garage after having another quick look at the car again.. had a quick look at the radiator and the core is only 15mm give or take!!!!??
i dont know how i missed it before but just checked the part number on the top tank... PAT-APP-48-86457.. quick research reveals possible DE radiator or some sort :/
does anyone have the part number of their OEM radiator to confirm?
I think a new radiator is definitely a must!
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6214553
Clogged radiator, or fins on the water pump after that, more than likely a clogged radiator
As mentioned could be a faulty temp sender too, you never know....
Edited by GTRPSI
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6214685
I went ahead and just got a new all alloy radiator and silicone hoses. Got everything fitted fine. The workshop took it for a spin to get it up to temp and apparently thermostat wasnt opening!
Top hose was boiling and bottom hose was very cool.
After changing almost everything in the whole cooling system it ended up being a dodgy waterpump :(
Well at least the problem is now gone!
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6234006
did you do a timing belt kit when you did the water pump?
At least you know now that you won' thave any overheating problems.
FYI - 3/4 on the temp gauge is about 105 degrees according to my ecudatascan device which connects to the consult port.
From there it gets to 115 really quickly.
May have cost you a bit of money but at least you are not up for a broken motor.
here are a list of things ot try in order of cost (cheapest to most expensive) for others who may eventually come here and search for "overheating" "radiator" etc
Radiator cap - New from nissan - part number available in forums
New coolant (personaly I'd dump coolant, hose out radiator, fill with demineralised water and bleed off and drive for 30-40 minutes and repeat 3 times - letting it cool in between obviously)
new thermostat - New from Nissan - part number available in forums
now starts to get expensive....
New radiator or get your one cleaned by a radiator shop (keep in mind that if you get a new Thicker radiator, you may have issues with the factory Viscous clutch fan touching or the shroud not fitting - Shroud is VERY important to have on the radiator for the fan to work to full effect.)
New viscous clutch for the fan
New Water pump (might as well do the timing belt and make it a proper 100K service)
My suggestion is to NOT use a radiator flush kit that you can buy from supercheap etc - By doing so, mine got blocked more
I'd also replace the top and bottom radiator hose if replacing the radiator.
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6234094
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
