  • Replies 143
Posted Images
Hi mate, I'm after the piece just under the dash / steering wheel. I think it's called the dash surround? Do you have this?
Which off the following is this?
Centre console $60
Includes Gtr badge. One of the mounting screws is broken however this cannot be seen when the lining is placed inside.
Console stereo surround $30
Triple gauge cluster $60
This is the piece I want:
http://www.ebay.com.au/itm/Nissan-Skyline-R33-GTST-RB25DET-Spec-2-Dash-Surround-DRIFTBITZ-/270894916581?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f129863e5
Edited by Spunky Munky
Hey fatz, chasing the boot trims, all of them please (battery cover panel, side covers, tail light cover and boot carpet and board) Providing its all in good condition. Throw us a PM if you can mate
Cheers, Allan
Hey mate, I've tried to reach you a few times. I am not sure if you received my PM's. Can you please check your PM? Thank you.
you must be doing something wrong because i have got everyone's pm except yours
Is the front undertray from the front bar back of the radiator back, if its front bar back will you be home late this arvo
Righto, shell is basically stripped of everything worthwhile and will be going to the scrap yard next weekend
if there's anything else from it you need speak now so I can remove it for you :)
subframes have some surface rust, hard to tell whether it goes deeper than that
if you're local come check them out
Thanks bloke I'll pass as chasing complete rust free.
:cheers:
Cheers, Allan
sorry mate just saw your message, boot trim is sold already
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
