Ok, i did a quick search for the same problem, but i couldn't find anything.
I have an odd ticking noise coming from my engine bay, it's irregular, and only happens when im idling. it's coming from the drivers side of the engine bay. i'm fairly certain i have a dodgy AFM, and my only theory is that it's playing havok with the injectors so they're turning on and off randomly or whatever injectors do at idle. the idle does jump around slightly, between 700 and 1200, but usually sits around 700 - 800. it goes away as soon as i rev it and never happens while driving. is there anything serious that could go make that noise on that side of the car? it's sort of like an electronic ticking like a solenoid going spastic.
anywho, any help appreciated.
https://www.sau.com.au/forums/topic/38937-random-ticking-noise-in-engine-bay/
nah oil is fine, it's an electrical ticking noise, like a solenoid clikcing on and off at random intervals. whenever my idle is playing up is when it happens. if the idle is being a good boy on that day it won't do it. that's what led me to believe possible injector problem.
Interesting... I had a ticking noise., but it happened all the time... I found it out to be the electric window switch was playing up, when i put my window down, the switch would stay partly on, and it would tick (ie a solenoid). I've figured out aslong as i make sure the switch is off after i put my window down its fine... Probably not wat ur problem is, but thought it was worth a mention.
one solinoid that is fairly loud is the vvt solinoid which comes on as soon as there is movement of the throttle, your tps (throttle position sensor) could be dodgy and kicking the vvt solinoid in and out.
just a thought
this sounds like my problem, thanks dude. i'll have to get my TPS checked out.
If you have a dodgy AFM then there's a fair chance the idle's jumped because the ECU's in limp mode. Dodgy TPS shouldn't cause the idle to jump - I think the ECU resets its throttle reading when you start the car, ie it makes whatever it's reading then as 0% throttle.
I have the exact same ticking noise on my car. It's a worn lash adjuster. Nothing to worry about, just annoying. The reason it only ticks at or near idle is because that's when oil pressure is at its lowest, and if the adjuster is worn it'll return the oil more quickly than it should and so 'bleeds' itself. Think about trying to blow up a balloon with a small hole in it. If you only blow a little bit, it will stay flat. It you blow harder, so that you're putting in more air than the hole is letting out, the balloon will stay inflated.
Different oil doesn't fix it - well maybe something like 80W90 would, but that's not a good idea :rant:
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
