Yep I remember that, a mate of mine did similar - well more the doing mid 10s and 400kw on a stock motor (with just pump gas, no nitrous oxide, I must add) thing that the crowing and being banned thing :)
This car has flawless victory, however:
that thing is beautiful to watch, so smooth and unbelievably fast...its obviouslly well set up and a powerglide does help i guess but all I can say is....I WANT ONe!!!
I assume the only weak point for now is the HG and if that goes I'll replace it on mine, if for some reason it's more terminal than that then I'll likely throw another stocker in its place...
The NEO is a tough bit of gear and I hope it holds up :yes:
Agree. If I were running a NEO at your level I would swap it out for a stocker once it failed. If I had more than 2 let go I would consider building from there. In the end you could go through 4 or 5 stockers before you reach the cost of building one properly.
Building a motor and only going for 300-400 seems like kind of a waste though :wacko:
The problem with it is, the motor is still susceptible to any one of so many failure points just like a stocker. Just takes one bit of carelessness or bad luck and then you have a very bad time. Seems like going "all in" in poker.
Hence I give props to anyone with the balls and inclination to push a built motor.
Exactly!
And it seems the Nissan seal of approval seems to hold together longer than a lot of "Builds" you see these days........
Agree with you both guys. I built my SR as the cost to me doing all the work myself was about the cost of two stockers anyway, so it was well justified. Plus I'm hoping to see more than what a stock SR will reliably do in the long run anyway.
Good tuning and good fuel makes a big difference. When that thread was started E85 wasn't really available (and still isn't practical for lots of us today).
Ethanol Content Sensor plus a decent ECU. There really is no argument of "it ain't close to me so I can't run E85" anymore.
In my case with two cars already set up and working pretty well the cost of buying a new ECU, bigger injectors, ethanol sensor and tuning does still make it impractical especially if the nearest E85 is 20-30mins away.
On a clean install I wouldn't muck around and just go for it.
What turbo would you guys recommend for a rb25 running e85.
Track car only!
1000cc injectors
power fc
z32
cam gears
profec 2 boost controller
3.5 inch exhaust
Front mount
Goal is for 8th mile drags!!
So need response and huge mid range performance
dont have a power goal just as fast as i can get down the 8th mile!
Any ideas ?
Been awhile since i posted on sau .The neo out me drift car let go a couple of months ago running 320 rwkw BUT beleive this had nothing to do with the power im under the impression it pumped all the oil into the head and then left the bottom end dry spinning the bearing and chucking a rod.
So got another standard neo to go back in its place this time it will be reciving some oil restrictors a head drain and a 7.5l gated sump to hopefully over come the oiling issuse .
Also thinking of changing over to e85 see what itll make hopefully add some more reliability to it aswell.
Ouch :O
Ouch :O
This happend on the skid pan after about 3 mins of 5000 -limeter of third.So it was under some hard conditions.see how the new engine holds up and see what it can make with some fruit juice
Well that explains a bit ;) Nice one haha
i'd say your diagnosis is spot on then! lol
RB's without custom drains and restrictors don't like 3+ minutes of limiter much at all hahaha
Just broke into the 300kw bracket....
R33 Series 2
mods:ViPec ECU
Haltech Flex Sensor
GT3076r .82 Low mount, Internally gated
APR head Studs
Metal Head Gasket
3" turbo back exhaust
Walbro 400L pump
Tomei Cams
740 Nismo Injectors
fuel:E85
power: 450hp [335kw] on 24psi
oil: Motul 20W-50
useage: Used to be daily, making its way to cruiser status
lifespan: had it for 4yrs, bought stock as a rock.
failure: Had head problems in the past when running 350hp on pump98
comments: Gains for E85 was 105hp over my Pump power of 346hp on 20psi.
Next mods will probably be new clutch, injectors & External Fuel setup
Edited by SCR48
R33 Series 2
mods:ViPec ECU
Haltech Flex Sensor
APR head Studs
Metal Head Gasket
Walbro 400L pump
Tomei Cams
740 Nismo Injectors
fuel:E85
oil: Motul 20W-50
Why the upgrade of the injectors and fuel setup? Is it on the limit?
Injectors are reaching their limit for E85, I upgraded my fuel pump tihs week from a walbro 255 to 400 to handle the E85. More of a bandaid till i have the $$ for a full external setup.
255 fuel pump was maxing out with the car makeing 405hp and a mix of 70% pump98 and 30% E85. to get the full benefits of e85 it needed changing
With the Haltech sensor i can now run any blend of pump to E85 i like and the tune will change accordingly.
Very surprised by overall gains
Edited by SCR48
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
