Yep I remember that, a mate of mine did similar - well more the doing mid 10s and 400kw on a stock motor (with just pump gas, no nitrous oxide, I must add) thing that the crowing and being banned thing :)
This car has flawless victory, however:
that thing is beautiful to watch, so smooth and unbelievably fast...its obviouslly well set up and a powerglide does help i guess but all I can say is....I WANT ONe!!!
I assume the only weak point for now is the HG and if that goes I'll replace it on mine, if for some reason it's more terminal than that then I'll likely throw another stocker in its place...
The NEO is a tough bit of gear and I hope it holds up :yes:
Agree. If I were running a NEO at your level I would swap it out for a stocker once it failed. If I had more than 2 let go I would consider building from there. In the end you could go through 4 or 5 stockers before you reach the cost of building one properly.
Building a motor and only going for 300-400 seems like kind of a waste though :wacko:
The problem with it is, the motor is still susceptible to any one of so many failure points just like a stocker. Just takes one bit of carelessness or bad luck and then you have a very bad time. Seems like going "all in" in poker.
Hence I give props to anyone with the balls and inclination to push a built motor.
Exactly!
And it seems the Nissan seal of approval seems to hold together longer than a lot of "Builds" you see these days........
Agree with you both guys. I built my SR as the cost to me doing all the work myself was about the cost of two stockers anyway, so it was well justified. Plus I'm hoping to see more than what a stock SR will reliably do in the long run anyway.
Good tuning and good fuel makes a big difference. When that thread was started E85 wasn't really available (and still isn't practical for lots of us today).
Ethanol Content Sensor plus a decent ECU. There really is no argument of "it ain't close to me so I can't run E85" anymore.
In my case with two cars already set up and working pretty well the cost of buying a new ECU, bigger injectors, ethanol sensor and tuning does still make it impractical especially if the nearest E85 is 20-30mins away.
On a clean install I wouldn't muck around and just go for it.
What turbo would you guys recommend for a rb25 running e85.
Track car only!
1000cc injectors
power fc
z32
cam gears
profec 2 boost controller
3.5 inch exhaust
Front mount
Goal is for 8th mile drags!!
So need response and huge mid range performance
dont have a power goal just as fast as i can get down the 8th mile!
Any ideas ?
Been awhile since i posted on sau .The neo out me drift car let go a couple of months ago running 320 rwkw BUT beleive this had nothing to do with the power im under the impression it pumped all the oil into the head and then left the bottom end dry spinning the bearing and chucking a rod.
So got another standard neo to go back in its place this time it will be reciving some oil restrictors a head drain and a 7.5l gated sump to hopefully over come the oiling issuse .
Also thinking of changing over to e85 see what itll make hopefully add some more reliability to it aswell.
Ouch :O
Ouch :O
This happend on the skid pan after about 3 mins of 5000 -limeter of third.So it was under some hard conditions.see how the new engine holds up and see what it can make with some fruit juice
Well that explains a bit ;) Nice one haha
i'd say your diagnosis is spot on then! lol
RB's without custom drains and restrictors don't like 3+ minutes of limiter much at all hahaha
Just broke into the 300kw bracket....
R33 Series 2
mods:ViPec ECU
Haltech Flex Sensor
GT3076r .82 Low mount, Internally gated
APR head Studs
Metal Head Gasket
3" turbo back exhaust
Walbro 400L pump
Tomei Cams
740 Nismo Injectors
fuel:E85
power: 450hp [335kw] on 24psi
oil: Motul 20W-50
useage: Used to be daily, making its way to cruiser status
lifespan: had it for 4yrs, bought stock as a rock.
failure: Had head problems in the past when running 350hp on pump98
comments: Gains for E85 was 105hp over my Pump power of 346hp on 20psi.
Next mods will probably be new clutch, injectors & External Fuel setup
Edited by SCR48
R33 Series 2
mods:ViPec ECU
Haltech Flex Sensor
APR head Studs
Metal Head Gasket
Walbro 400L pump
Tomei Cams
740 Nismo Injectors
fuel:E85
oil: Motul 20W-50
Why the upgrade of the injectors and fuel setup? Is it on the limit?
Injectors are reaching their limit for E85, I upgraded my fuel pump tihs week from a walbro 255 to 400 to handle the E85. More of a bandaid till i have the $$ for a full external setup.
255 fuel pump was maxing out with the car makeing 405hp and a mix of 70% pump98 and 30% E85. to get the full benefits of e85 it needed changing
With the Haltech sensor i can now run any blend of pump to E85 i like and the tune will change accordingly.
Very surprised by overall gains
Edited by SCR48
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
