Got mine from Greenline, to be fair I can't remember what duty cycle they were at but I remember working out that it would be a stretch trying for 17psi on E85 with them on the GT3076R
Sent from my GT-I9505 using Tapatalk 2
I don't recon the 555's would make it with the 3076 on e85
with the 2835 they were reeeeeeally stretched and i didn't personally want to mush them any further.
@ 323rwkw and 20psi we hit the point of diminishing return on the power figure so we called it quits anyway
I had 550's and was told to go too 1000's which i did! Turned out they were incorrect and dodgy and have now been replaced by 2000s :P A bit of headroom now haha
That's very decent for 555's. From memory my Nismo 740s were @ roughly 80-85% on last tune at 304kw with a bit of thickness up top. Enough for what I want but not a hell of a lot more.
I don't know if the nismo injectors have a nicer spray pattern for low rpm/load than ID injectors, but at least I have enough flow for the job either way.
Ok guys, noob question in regards to 200L drums of fuel.. It's got a proseal cap and for the life of me I can't get it undone. Apparently there is a proper tool but ppl open them with screwdrivers. I've tried a lot of tools even tried having two vertical screwdrivers and one horizontally between them to twist and it still won't budge.
Anyone with tricks to the trade for this?
you tried heating the lid and using a pipe wrench.Nothing has ever beaten a pipe wrench with my strugle to undo anything
TBH i think Nismo probably just make 740's and paint them different colours
I wish it were true for mine, I had Nismo 555cc and they behaved exactly like you would expect 555cc injectors to behave - as I mentioned earlier... meant I wouldn't get away with ethanol :(
Soft! :whistling:
This here is my unopened rb25. Has a surge tank,
044 pump, 750bosch injectors, e85 fuel and an apexi
Power fc. Turbo is a hks 3037 .63 rear housing with a
Garrett front cover. Tuned by smmotorsports making
344.1rwkw on only 15.8 psi. Since October last year
I've done 5 drift events, Phillip island sprints and
Winton Vic time attack over Easter. Engine still has
no signs Of wear.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
