Stock RB25DET (head bolts, head gasket, internals)
hks 256/264 cams and ex cam gear
nismo 740cc injectors
apexi pfc with a z32
garrett gt3076 .82 turbo with tial 44mm gate
GTR intercooler
Greddy plenum
Tomei 500hp lift pump with a 044 feed
Nismo fuel reg
23psi and BP Ultimate
BIG thanks to Trent and Cat from Chequered Tuning. Glad to see there are still legit people in the Auto industry.
That is an excellent result! Nice work, got to be happy with that - over 200kw @ wheels at 4000rpm and nearly 340kw on BP98... imagine it on E85! The old GT3076Rs don't get that much love these days, but they do the job.
Lithium: the 3076r is an awesome turbo for the street. Great mix of response and power on pump fuel. They may not make mega hp but for the 300kw range they are perfect.
I'll be heading to calder park drag strip soonish and will post up vids
So what's the definitive answer on turbo choice to reach this cute little club with the most response possible? On boring 98 that is, with supporting mods ect ect.
I'm thinking GTX3071? Just want to touch 300 or just under, typically seeing 290kw ish @20 psi on this turbo. Anything better suited?
Edited by owen1r
They dont get much love when there are HTA's in their place :P
Trents confident it will go high 3 hundy to 400kw on e85 or c16.
I'll muck around with the car like this for a while. She's fast :D
363rwkw seems to be the magic number mate, we punished mine and no matter what we did it wouldn't go 1kw more! Same result on NYTSKYs built engine too! They just have nothing left to give after that!
That's the limit on JEM's dyno, but things would probably be different on the Dynapack - still reckon you should take yours to a hubber sometime, or a dragstrip and get some ridiculous mph ;) That'd put things into perspective! :D
Oh yeah good point! Oops...
Will get there this year.... So far i have booked 6 events for the year and hopefully one of them will be Coota!
360kw with better response than I already have is more than enough. If I change turbos ill go forced performance 3076
Yeah nice one! Was the best thing i ever did, drives so much better everywhere off boost and on! In saying that i do miss the 3076 super whistle lol
T67 8 or 10cm
Its pretty responsive. Sounds like a normal medium frame turbo to me as im running an intake pipe n apexi pod. I've actually never heard a 3076 with the anti surge cover. Are there any up sides apart from sound?
There is probably a few vids on my Pootube page "34GEETEETEE1" with the old turbo that will give an indication of sound....
Stock head/block
550cc inj
Chinese exh manifold
Chinese intake manifold
44mm gate
z32 afm
pfc
Gtx 3076 0.82 @26psi
C16 :devil:
362 rwkw
Wow, what is this car to be used for?
Inj 550cc? :blink:
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
