hey guys just wondering about the gt3076
what kind of power figures can the gt3076 with the internal wastegate .76 rear housing make on a rb25det with supporting mods
from my understanding and results ive seen that they are not the best choice of rear housing for the turbo to suit the rb25 engine
can anyone help
https://www.sau.com.au/forums/topic/389707-gt3076r-with-76-rear/
  • Replies 62
ive never heard of that one, far as i know its either .63 or .82 , i would not even try non genuine garrett housing, you looking for trouble there, if you want the best results then dont try and take short cuts, stay with a .82
yeah i know i had a guy offer me a gt3076
its the .76 internal gate rear housing which is a direct bolt on for our rb20/rb25 dump pipe pleaces like GCG and tweakit sell it
im a bit worried as its not a genuine garrett housing as i only want a .82 and im happy to make my own dump pipe to suit
but the guy claims he made 284rwkw on a rb25 on bp98 with only 18psi
if it were me , i wouldnt take any chances, by the the time you've paid for it to be dyno tuning and it turns out the housing is crap ,you'll wish you'd just gone genuine,
the .82 is proven over time so atleast theres confidence in it.. up to you though how much you want to give things a go and re dyno etc.
i went .82 with external cause i wanted to eliminate any issues..
hmmm... is he a known trader/common on the forum?
just interesting that he made exactly the same power as me on exactly the same boost on 98....
just make sure he is legit.....
those avo type housings are tried and tested............ and turned out to be shit
you can find plenty of info about them on this forum if you look hard enough. its a lucky dip how it will go, some are usable some are just rubbish and you definitely wont get your 300kw that you want.
if you want a simple 300kw follow Stao's mods to the tee and bolt a G3 on it. you should get over 300.
Why not a SS2, more responsive than a G3 and is just in the 300rwkw category?
Why not a SS2, more responsive than a G3 and is 'just' in the 300rwkw category?
Are you sure its .76?? Most likely to be a .73AR internal wastegate Skyline housing from AVO turboworld
http://www.avoturbo.com/pdf/gts_exhaust_housing.pdf
Rated to between 280-300rwkw at around 20-22psi on 98Ron fuel.
Nothing wrong with this exhaust housing whatsoever, been running it for a number of years. Spools up nicely, puts down the power well.
"very shit" my arse
Didn't mean to offend was referring to it making 300rwke on sensible boost, tweakit as I said .76
http://www.tweakit.net/shop/product_info.php?cPath=326_367_378&products_id=6637
Not to sure if It will make the power I'm after they do claim it will make 330rwkw but I'm sure that's prob 25/30psi lol
I haven't really seen any results on the ss2 in the 300rwkw on 18psi
And what's the transition of boost like ie between gears and driving in traffic,
Then it comes down to price
As a Garrett gt3076 will be cheaper what will make close to 300 easier with less lag and more reliability
if i was to get a gt3076 im happy to go external wastegate thats not a problem
but im atill trying to convince myself if a hypergear will be as responsive as a 3076 and make 300 well 290rwkw IW on 18psi but looking at dynos it seems they spike a bit
can anyone comment what would be the better option
its goin to cost about the same for the hypergear as its goin to for the 3076
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
