Morning.
r33 gtst series 1
splitfire coils
stock injectors
7's gapped at 1 or .9
This morning when i turned my car on i had terrible idle, i currently have a very mild miss on warm idle and always have, but this morning, and only this morning (so far) it just decided to idle shit, the motor was rocking and you could feel it through the car, i wouldn't say it was a crippling rocking, but enough to shake the motor and car.
The rocking was a perfectly sequential fast paced rock, as apposed to an occasional light miss from the motor. it felt like it was missing every revolution and about 6-8 times a second on startup idle (1200-1500rpm) it almost felt as if you had washed the engine and a bit of water went into the valley, and you get that miss that it does.
I should note that the idle was starting to smooth out as the car was on, but turned it off before it was fully gone.
My guess is an injector is blocked? or a spark plug fault? but its weird that this didnt happen yesterday when i used the car. Could this be in relation to my usual very mild occasional miss that i get normally?
Ive tried to give as much info as possible, if i've missed anything let me know.
Cheers guise
https://www.sau.com.au/forums/topic/389746-terrible-start-up-idle-rocking/
check your plugs first man... i'm guessing that they are gone.
did you drive it at all? and if so did the problem rectify itself after a while?
I just reversed the car across the road, and i think the idle was starting to smooth out after about 30 secs to a minute, but didnt want to leave it running, since i thought it might be leaning out on a cylinder or something.
I will check the plugs.
i went out just now and the idle was fine, but id still like to know what happened, as i assume this can happen again.
Edited by ClutchBurndout-:(
Those misses you say you get when warm are not misses, they are lean pops. They don't happen on idle due to the richness that the car runs to warm the engine up. If you drive your car when its in its cold state and switch it off soon after, the unburnt fuel can quickly foul old plugs. Ive had mornings where my car will start and misfire its face off. Change the plugs and bam its back to normal. My car was running rich all over the place so after I fixed that it didn't happen.
lean pops you say? not on idle? this ONLY happens on idle, how do i fix the lean pops on idle? checking for fouled plugs? what plugs will solve this?
i was very low on fuel yesterday, but filled up yesterday and drove another 30mins home on new fuel, that wouldnt affect it this morning?
so which plugs to use, some are saying BCPR7ES and some are saying BKR6ES?
  • 4 months later...
7's are too cold for your application. Go down a heat range of 6. If the plugs can't get warm enough to it's operating temperature it can't burn off the excess carbon on the plug to clean itself and foul. Assuming your still running stock injectors your not putting out big power and 7's are too cold.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
