Hey guys,
Never made a dose pipe before but i have just turbo'd my mates 31 with a T3/T4 T04E and was playing around with various suggestions i found on the net but with no success, anyhow he isn't really fussed whether his dose's or not but i am about to turbo my 31 to give to my girlfriend and she really wants it to dose, so if anyone could help me out with some measurements or even better, pics..that would be awesome :rolleyes:
Thanks, Daniel.
https://www.sau.com.au/forums/topic/389832-help-making-a-dose-pipe/
2.5" Silicone Joiner, 2.5" or 3" wide, 17cm long piece of pipe preferably 45 degree angle, Attach to mouth of turbo, attach some memory hose to the end. It's actually the easiest thing to make, if you need measurements then you probably shouldn't be doing it :P There is no "Right" way.
Ah cheers mate, i tried a piece of short 3" steel pipe, also a reducer and short 2.5" steel pipe, and also a couple of different sized elbows, all i could seem to get was the usual compressor surge noise >_< i wasnt driving it when i tested it though, just revving it
I've fkt around with dose pipes for about a million years now.
I had the same turbo on my VL.
The best dose I could get was a 3" > 2.5" reducer to a straight pipe 11cm long with no pod on the end.
Any bends take the volume right out of it and making it longer makes it deeper.
i wasn't able to drive it as it wasn't finished yet but i was able to get it to surge pretty easily by revving it like in the video above ^ ... but i will drive it next time just to be sure.
Also what is clamped in the end of that pipe peter ?
