Hi there ppls.
I've recently purchased an Apexi GT Spec Cooler kit., the usual 600 x 400 etc etc.
I want it to be a stealth fitment, so it needs to be black.
I'm tossing up between powder coating it or anodising it.
Does anybody have any experience in doing either of these things to their cooler.
Regarding powder coating, I'm not sure whether I will block up any parts of the frontal area of the cooler.
Regarding the anodising, I'm not sure whether it will adversly effect the surface of the cooler, and it there is any coating already on it that the anodising will destroy. Will I be able to submerge the cooler in the anodising liquid without any troubles??
All help appreciated
BASS OUT
https://www.sau.com.au/forums/topic/38991-stealth-intercooler/
The other option that works fairly well for stealth is just keeping the intercooler silver and going for the aluminium mesh. Basically from a metre away it will be hard to impossible to spot.
Mine is pretty difficult to see that it has a FMIC unless you get up close (where they are going to see a black one anyhow)
I've always wondered that. Is black more efficient even if its not reflecting ambient light?
The reason I understand black is more efficienent at absorbing heat when exposed to light, is that it aborbs all of the visible colour spectrum. How does this actually apply to heat absorbtion in a closed environment (e.g. under bonnet or the like) ?
I found this snippet..
Actually, rather than thinking of them as absorbers of heat, darker colors are
better absorbers of light and thereby become better radiators of heat.
Consider the following:
The color of an object depends on the wavelengths of colors reflected from the
object. A red apple is red because red wavelengths in white light are
reflected and other wavelengths are absorbed. In fact, if a red apple were to be
illuminated by light that had no red wavelengths, the apple would appear
almost black.
When a black object is illuminated by white light, all wavelengths are absorbed
and none are reflected -- that's why the object appears black. I learned this
the hard way one dark night when I tried to use my flashlight locate a Black
Angus steer that had escaped our pen. All I could see when I shined the light
on the steer were two glowing eyes.
Getting back to the point; when light is absorbed by a black object, the energy
carried by the light doesn't just disappear. Rather, it raises the energy of
the object doing the absorbing. The object, in turn, releases the absorbed
energy by emitting longer wavelength, lower energy infrared (heat). This
transformation of light into heat is the key to understanding the process
because it accounts for the law of conservation of energy. Light just doesn't
disappear when it strikes a black object -- it's transformed into another kind
of radiation that is either radiated from or retained within the black
object.
The darker the object, the better its emission of heat because it is a better
absorber of light.
The absorbtion of light is a test and characteristic of a black body radiator not the reason it is a better absorber of heat (hence a better heat sink). For that you need to ask 'how' it absorbs heat (do a search under black body radiator theory). We can measure the surface temperature under load of the black and standard intercooler with an optical pyrometer and see the difference in a pitch black (no external visable light source) enviroment for example. Bottom line is there is the same benifit at night time.
the reason i ask.. is i have some under bonnet intercooler piping that i may get powdercoated soon. The obvious choice would be silver to match everything else. But if black was inherently more efficient at dissipating heat then maybe it would be a better idea to go black. I think you have answered my question rev210.
yes, i know HPC would be the most efficient.. but the extra cost probably isn't worth it in my car.
intercooler piping is a different sort of issue.
Since black is good at radiating heat and absorbing it you really only want it on the intercooler. Black pipes after the intercooler (the colder ones) will absorb more heat than if they were silver (only a little more heat). The turbo to intercooler pipe can get very hot so insulation is the name of the game in both cases. If you don't want to thermal tape them both then stick with silver.
I hope that helps
But out of interest doesnt hot gas (ie air) flow faster? Obviouly there is a happy medium, because if you go too hot the air will be useless, and too cold wont flow. Sooo wouldnt you want some sort of heat in the piping???
your best option is to chrome your cooler, as this will keep your cooler colder and therfore keeping the air running through it cooler.
the colder the air the beter the flow and beter for your engine
:confused:
...stealthy, that.
  • 8 months later...
When it comes to coating a surface that you want to radiate heat from, you want the thinnest coating possible as to avoid creating any kind of insulating barrier. Personally, i would avoid painting it, even a thin coat. My reasons being a light coat of paint from a pressure pack never gives a good consistent professional finish. The smoother you want the finish to be, the more layers you have to build up.
The best thing to do is to have it anodized. Sure, it will cost more, but the end result will be a professional finish with flawless coverage consistency, much better than youll ever get with a pressure pack, and its thickness will be in the order of microns.
Sure there are some things you can do yourself, and enjoy doing at the same time, but nothing is better than a done job right, even if you didnt do it.
NO.
Ideally you would want the complete intake tract supercooled so that the air is denser and you can burn more fuel and make more power.
Just look at things like the Nitrous Express Intercooler spray kits, as used on 2fast2furious r34, by using super cold gas to really chill the cooler and drop intake temps.
NO.
Just look at things like the Nitrous Express Intercooler spray kits, as used on 2fast2furious r34, by using super cold gas to really chill the cooler and drop intake temps. There is not an issue of air not flowing because it gets too cold.
Turbo Tits.
Can't anodise an intercooler.
I spoke to my aluminum guys about it.
Too many fins and little nooks and crannys that the chemicals they use wouldn't be able to get in there properly.
I just got a pressure pack and sprayed mine and it looke great, works great.
Remember, on a road car an intercooler is just a heat sink anyway.
BASS OUT
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
