Okay,
So my current diff is on its way out - the usual whines, clunks and noises that come from a diff which has done 170,000 kms.
So in saying that, I'm on the lookout for a replacement...
1st choice (cheapest) would be to overhaul & shim up the diff I have in the car -
advantages: fixes the clunks noises etc., locks better that currently, cheap
disadvantages: its a V-LSD. They have average performance at best. Shimming accelerates wear on the crown wheel from what I had read and overall is just a bandaid for a bullet wound.
2nd choice would be to purchase a new or used Nismo/OS Giken/Cusco etc. -
advantages: Nismo item is comfortable (almost) as OEM, locks consistently, considerably newer item overall
disadvantages: costly, if 2nd hand unknown condition etc.
3rd choice would be to install a diff from another car i.e. S15 torsen diff -
advantages: locks consistently (except for in zero traction environment), cheap
disadvantages: zero traction = zero lock (driveways etc.), unknown condition
What is your thoughts? Which path should I go down considering that cost, effectiveness, performance and condition of the item all need to be considered...
Cheers,
David
https://www.sau.com.au/forums/topic/390011-differential-choices-for-r32-gtst/
I'm currently in the process of doing #3. Is turning out to be more expensive than I expected though. I initially bought a diff advertised as R34 manual LSD (which are supposed to be 4.11 and torsen). But it was a 4.11 VLSD. So either the specs on R34s were more flexible than I thought, or I got sold an R33 unit. Then I bought an S15 torsen centre. That seems fine, but the ratio is Silvia tall. So we built Frankendiff. Moved the 4.11 gears to the torsen centre and then put the lot into my R32 housing. Wasn't easy to get the CW&P set up correctly, so now it's at a diff shop getting set up. So there's $300+ for purchased diffs and a couple hundred coming up to pay the diff shop. Still worth it though I think.
Sorry forgot to add that...
Car is pretty much 95% street, 5% track.
2-way is pretty much out of the question. There is just no need for it.
GTSBoy:
Yeh it seems the cheapest way to go about it. Best of both worlds IMO (cheap & still locks well for the way I use my car). But like you said, its a big ordeal to get it all setup. Unfortunately you had the added expense of the extra diff :yucky:
Also, problem is finding a 1.5 Nismo diff.
They don't pop up very often.
I have also been told the half shafts (AKA stub shafts) are different from OEM and you need the correct halfshafts supplied with teh diff from Nismo. These also rarely pop up correct for my car i.e. 5X1 bolt pattern etc.
Think the issue is more David doesn't see buying a new one as value for money, $1400 is a shitload, see lots of 2nd hand 2 ways for ~500 that cost nothing to get the clutches machined and set up with non aggressive preload but he wants a 1.5 which almost never come up second hand, hence the question, buy a torsen for not much? buy a 2 way that is slightly more aggressive than he wants or pay way too much for a new 1.5?
Imo a nismo 2 way with mild preload would be fine as I've had one and it drove like stock, but I don't think david wants to compromise there. Which means either lots of money for new 1.5 or a torsen that will be better than stock but not as good as a 1.5 way.
Guess it comes down to 2 metrics, cost and performance, what is more important? If it is cost go torsen, if it is performance go a 1.5 way. Though the 2nd hand 2 way is screaming as a fantastic middle ground to me.
http://www.nengun.com/nismo/gt-lsd-pro
1.5 and 2 way listed there. Email and ask them, as im pretty sure the Nismo kit comes with new 1/2 shafts.
I picked up a Nismo 2 way 2nd hand for only $600 in apparently immaculate condition, i then sent it to a local diff expert and got him to rotate it to 1.5 way as it will see a lot of street work and occasional track, its yet to be driven on but condition looked mint inside, yes the half shafts are different to stock.
Just a quick note in regards to the half shafts, the Nismo LSD's are supplied with OEM Nissan half-shafts BUT, they are equal length (short IIRC) as opposed to the 1xlong/1xshort which is standard.
I bought my 2 way for $900 which was just run in (basically brand new). Came with new 1/2 shafts when I got it also.
I've noticed that you can indeed rotate the housings between 1,1.5,2 way on some diffs, didn't know you could do it with the nismos, that is interesting as hell!
Pretty sure it is just Nismo and Cusco that you can do it with, unsure if there are others but its an awesome option. The Nismo Pro (What i have) you need to dismantle it and rotate it, but i believe the Pro TT is better in design? Either way i was happy with the purchase!!
That's a good buy!!! Its pretty hard to find R34GTT bits so i was stoked when i got my diff!
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
