I got hold of a turbosmart boost controller, the bleed vavle style ones, I've put the boost up around 2 - 3 psi and I cant rev past 5000rpm!!!! It pings too much!!!! :ghost:
My mods are:
3" Mandrel bent cat back exhaust
Pod Air Filter
What should I do to recitfy the problem? (Please dont say put the boost back down, coz then it defeats the purpose of modifying it doesnt it! duh!)
Thanks guys!
https://www.sau.com.au/forums/topic/39055-need-help-pinging/
put the boost back down til you get an intercooler.
or, get an air box to lower your intake temps....
but either way, a 2 psi increase (bringing it to around 9/10psi) causing detonation with those mods is pretty bad.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-792763
what Christian said,
turn the boost down until you get a FMIC and a cold air intake system (either ducting from the front bar into a modified airbox or whatever else you come up with).
whats more important to you??? having a car that drives reliably or a sick hectic motor that'll shit itself sooner rather than later?
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793108
Since you've put it so well - Sick hektic :cheers: - Hahahaha joking joking
Yeh I just found out I've done 15,000kms since buying the car in which I dont know when the Sparkies have been changed so they will be changed soon.
Are Iridium plugs really worth the $16 each asking price??
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793124
yeh mate.
but in all honesty a FULL service should have been the first thing you did when buying the car.. unless there's a log book history of it being done in a reasonable time frame
I had nfi when anything on my car was done so we did everything the week I got it
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793136
If your car is pinging like mad with 2psi extra you've got some *big* problems.
Are you sure its not a missfire? Thats much more common at 5000rpm, do a search, there are heaps of suggestions for solutions.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793256
From experience, prolonged use of octane boost will stuff your plugs, a real pain especially if you have forked out for iridiums.
As with what Prank said, if you are pinging with such a small increase in boost, that is defiantely a cause for concern and I would bet that there is something else going on. My advice is get the car to a reputable workshop asap for a complete checkup before things really go pear shaped.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-794033
Do a *full* service on it. Including Dyno tune / Power run - FIRST UP.
* Plugs
* Fuel Filter
* Oil Filter
* Air filter
* Oil
* Gearbox and Diff oil too
* Drain & Flush your radiator
* Cheack your fuel pressure
* Make sure you have no vaccuum leaks or pipe leaks - ie intercooler piping etc
Do not attempt to increase boost / power without knowing where you are starting from. ie get a baseline.
Do a compression test / leakdown test also. Just to be sure and for a baseline.
Plan your mods - do them bit at a time and get dyno results between mods.
Do not use octane boost to fix continual pinging.
Report back here with your progress and we will keep advising you.
You should be able to run 2-3 PSI on top of stock without any problems - bit get a bigger intercooler to be sure - a GTR cooler for example.
Hope it all goes well
When all else fails a 50 HP shot of NOS should fix your pinging :D
Cheers,
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-794824
* Plugs
* Fuel Filter
* Oil Filter
* Air filter
* Oil
I would suggest having your timing belt changed also, espically if your car is getting towards the 100,000kms mark.
Are you running an aftermarket boost gauge? sounds like a dumb question... but the stock one is not worth much I found.
Cheers.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-795224
I would be careful with that one... I first installed the boost controller (as I just couldn't wait to feel that bigger boost) even though I had the boost guage there ready to go... took it for a spin with what we guessed to be about 0.8 - 0.9 bar, was sitting just off the line with the +7 on the dash. Went like gold, but missed at around 4500-5000 rpm. installed a boost guage and it read 1.45 bar... hence the miss!
Just be careful and even see if you can borrow a guage of someone just to set your boost!
Dan.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-796457
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
