I got hold of a turbosmart boost controller, the bleed vavle style ones, I've put the boost up around 2 - 3 psi and I cant rev past 5000rpm!!!! It pings too much!!!! :ghost:
My mods are:
3" Mandrel bent cat back exhaust
Pod Air Filter
What should I do to recitfy the problem? (Please dont say put the boost back down, coz then it defeats the purpose of modifying it doesnt it! duh!)
Thanks guys!
https://www.sau.com.au/forums/topic/39055-need-help-pinging/
put the boost back down til you get an intercooler.
or, get an air box to lower your intake temps....
but either way, a 2 psi increase (bringing it to around 9/10psi) causing detonation with those mods is pretty bad.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-792763
what Christian said,
turn the boost down until you get a FMIC and a cold air intake system (either ducting from the front bar into a modified airbox or whatever else you come up with).
whats more important to you??? having a car that drives reliably or a sick hectic motor that'll shit itself sooner rather than later?
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793108
Since you've put it so well - Sick hektic :cheers: - Hahahaha joking joking
Yeh I just found out I've done 15,000kms since buying the car in which I dont know when the Sparkies have been changed so they will be changed soon.
Are Iridium plugs really worth the $16 each asking price??
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793124
yeh mate.
but in all honesty a FULL service should have been the first thing you did when buying the car.. unless there's a log book history of it being done in a reasonable time frame
I had nfi when anything on my car was done so we did everything the week I got it
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793136
If your car is pinging like mad with 2psi extra you've got some *big* problems.
Are you sure its not a missfire? Thats much more common at 5000rpm, do a search, there are heaps of suggestions for solutions.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793256
From experience, prolonged use of octane boost will stuff your plugs, a real pain especially if you have forked out for iridiums.
As with what Prank said, if you are pinging with such a small increase in boost, that is defiantely a cause for concern and I would bet that there is something else going on. My advice is get the car to a reputable workshop asap for a complete checkup before things really go pear shaped.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-794033
Do a *full* service on it. Including Dyno tune / Power run - FIRST UP.
* Plugs
* Fuel Filter
* Oil Filter
* Air filter
* Oil
* Gearbox and Diff oil too
* Drain & Flush your radiator
* Cheack your fuel pressure
* Make sure you have no vaccuum leaks or pipe leaks - ie intercooler piping etc
Do not attempt to increase boost / power without knowing where you are starting from. ie get a baseline.
Do a compression test / leakdown test also. Just to be sure and for a baseline.
Plan your mods - do them bit at a time and get dyno results between mods.
Do not use octane boost to fix continual pinging.
Report back here with your progress and we will keep advising you.
You should be able to run 2-3 PSI on top of stock without any problems - bit get a bigger intercooler to be sure - a GTR cooler for example.
Hope it all goes well
When all else fails a 50 HP shot of NOS should fix your pinging :D
Cheers,
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-794824
* Plugs
* Fuel Filter
* Oil Filter
* Air filter
* Oil
I would suggest having your timing belt changed also, espically if your car is getting towards the 100,000kms mark.
Are you running an aftermarket boost gauge? sounds like a dumb question... but the stock one is not worth much I found.
Cheers.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-795224
I would be careful with that one... I first installed the boost controller (as I just couldn't wait to feel that bigger boost) even though I had the boost guage there ready to go... took it for a spin with what we guessed to be about 0.8 - 0.9 bar, was sitting just off the line with the +7 on the dash. Went like gold, but missed at around 4500-5000 rpm. installed a boost guage and it read 1.45 bar... hence the miss!
Just be careful and even see if you can borrow a guage of someone just to set your boost!
Dan.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-796457
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
