Hmmmm I thought OH closed down after James passed away?
I bought one from eBay for $100 ;) now I'm trying to find a solution to make my exhaust quiet hahahaha! I know Advanced Jap rent out standard exhausts but it's being used at the moment
https://www.sau.com.au/forums/topic/391068-air-box/#findComment-6229907
still open, name change and someone else running the show.
https://www.sau.com.au/forums/topic/391068-air-box/#findComment-6230084
Nicole, I might have standard exhaust it could fit in your 33 but I'm selling it though.
How much Grant?! I don't know whether to swap to standard to pass the defect and then go back to my exhaust or whether to just go get a muffler put on it seeing as it doesn't have one,.. It's just a straight 3" from turbo back
I didn't get EPA'ed so I don't know if Vicroads have the ability to test the db? All the defect says is 'exhaust not to exceed noise limit'
https://www.sau.com.au/forums/topic/391068-air-box/#findComment-6230160
I'm selling it as whole with Y pipes but can separate, PM me with your offer.
Some roady tester will deem a/m exhaust as too loud, I've asked recently, they all want me to put standard exhaust when I went in for a RWC.
https://www.sau.com.au/forums/topic/391068-air-box/#findComment-6230286
I got the defect off yesterday :) I went in to Vicroads at 4.15pm and had 15 people in front of me ahhaha... I didn't have to give them a certificate he just wanted to hear the car to make sure it wasn't making the 'sssstttuuutututu' noise and that the exhaust wasn't loud.
I hate the exhaust on it now :( I went from a straight 3" from turbo back with no muffler to a 2" with rear muffler... I can't even hear the car when it's running now hahaha!
https://www.sau.com.au/forums/topic/391068-air-box/#findComment-6233562
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
