I have just bought a s2 stagea engine for my r34 gt-4 4wd manual but don't know what diff to use.
i have been told to use the na diffs which is 4.3:1
i have also been told to use the turbo diffs which is 4.11:1
so my question is what is the better diffs to use
the car is being used as a daily driver
https://www.sau.com.au/forums/topic/391197-question-what-diff-to-use/
I just installed 4.3 and is shit on freeway. sits up just under 4,000rpm.
4.11 was much more suitable but went 4.3 so I can turn 3rd easier.(stock power) Will be running 4.3 locked on track days and 4.1 as daily. Only half hour job swapping 'em so doesn't bother me.
In short answer is 4.11 as Nismoid said
The Stagea diff is 4.1 and your rear diff is 4.3 so you are going to have to change one. I would change the rear to suit the front so both 4.1
I would guess you now have more power than before so a slightly taller gear would be a good idea.
My Stagea with 4.1 diffs is doing 2700 rev/min at 110km/hr.
If I can find a non V-spec R34GTR diff I will be changing to 3.454:1 ( I have an RB30/25 with heaps of torque).
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
