Hi all,
Does anyone run spacers on their R34 GTT on stock wheels? Can you share some photos please?
Just interested in what they might look like ... and no, not keen on changing to a different set of wheels.
There's a fair bit of distance between the wheel and the guard in stock form:
You could possibly slot in a 20mm hub centric one in the rear and still have clearance?
Just an FYI, from what i have experienced with standard nissan wheels need to machine out the wheel to be able to use a hub centric spacer on them. or machine off the locating ring on the spacer, but then your wheel will not located properly.
looks like you are running a bit of negative camber in that photo if yu pulled that out the wheel wouldn't be so sunken at the top
I ran 25mm hubcentric spacers on mine, needed to have the guards rolled though running under -2 deg on the rear, the R34 GTT rims are recessed to accept spacers no problem.
My wheels look like in mlr's photo so it should be alright.
Yep, just pulled rear upper control arms out today, trying to get some eccentric SuperPro bushes onto them tomorrow to adjust :) Maybe that'll make it look a bit more decent, too.
20mm or below works but any more you will need to roll guards as said by others above.
Thanks guys, did you have any photos by any chance?
Sounds like 10mm might be enough and avoid rolling the guards ... Do they make hub centric spacers in 10mm?
  • 1 year later...
Ok.... finally got around to this. Bought some 20mm hub centric spacers and put them in all four corners.
What do you reckon, do I need to roll the guards? The car is not super low but the tyres are 'fatter' than most as they have the sidewall wheel guards that extend several mm past the rims (Eagle F1), and I'm wondering if they're going to rub under load...?
Pics below, apologies for the filthy wheels. Fronts:
Rears:
Cheers
Shouldn't rub unless you corner heavily, depends also on how stiff your suspension is. Do you have aftermarket coilovers?
BTW, did you buy your hub-centric's from GKtech?
I need some to push my 9.5 +15's out now that I flared my rears 40mm :)
Thanks mate - yes I've got BC BR's on but they're not super stiff. Might look into rolling the guards just in case..
The spacers are off ebay, exactly the same specs as the GKtech's except for the stud length. The quality seems good, and a very good price. I didn't want extended studs as I want to be able to put the centre caps back on, otherwise would have gone the GK's.
40mm, that's some serious flaring, put up some pics when it's done :)
Quick question - since installing the spacers (together with adjustable upper control arms and radius rods) I am experiencing slight knocking/jarring at full lock e.g. when shuffling around to park.
I have done a cursory check of clearances, the tyres don't seem to touch and I can't see any marks anywhere ... Has anyone else had similar, I wonder what it could be?
  • 1 month later...
I ended up zip-tieing the plastic inner guard lining in front of the wheels and it's much better now, no more jarring.
There's also a little plastic 'ridge' on the rear side that you just push in for a tiny bit more clearance.
  • 1 month later...
Just in case anyone is curious I'm running these 20mm ebay spacers: http://www.ebay.com.au/itm/Pair-5-Stud-20mm-Thick-5x114-3mm-PCD-M12xP1-25-Nissan-Wheel-Spacers-Drift-Race-/200901360401?pt=AU_Car_Parts_Accessories&hash=item2ec6a77b11
Couple of tips from my wheel alignment joint: 1) the wheel nuts that come with the spacers go on the original wheel studs, 2) use loctite on them.
Edited by V28VX37
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
