OK, as the title suggests I just got a SAFCII- paid $380 brand new.
I am pretty much a noob at this sort of thing but wanna get better. :Oops:
I have a R33 GTSt Series 1 with 100K on the speedo just had major service. It has a full 3" exhaust, turbosmart boost controller(5psi for normal running, 11psi for track), and turbosmart BOV (although this was fitted when i brought it and i'm thinkin bout going back to original) and also a turbo timer which i actually use.
I was wondering how to tune this thing and what i should look out for when installing it? (I havn';t recieved it yet)
I have read briefly somewhere that you should initially tune it with the aid of a dyno? WOuld this be the best thing to do?
Any help or information on this thing would be great.
:D
JaFF
ONLY tune it on a dyno!
whatever you do, do not fiddle with it unless its on a dyno so you can check your a/f ratios.
its pretty easy to lean it out and do serious damage. once you have installed it, just leave all the settings on 0 (zero) until you are able to get some dyno time. mine gave good results
good luck.
just wondering what are these things like if you have upgraded the turbo got fmic and go and buy 550cc injectors.. could you make it run better easily or is it better to get remap/new ecu.. i know the second option would be better but for a patch up till i can afford a new ecu would it be fine?
rbs13, your much better off getting a remap. The SAFC isnt designed to accomodate new injectors, let alone a bigger turbo on topetc. Remember, all you're doing is fooling the stock ECU, and it becomes a limitation itself eventually! It would help things quite a bit tho, and you can always sell the SAFC again after you're done.
but the SAFCII is like $400 or so, then you've got your full dyno tune time .. how long would it need on a dyno to tune a SAFCII? probably end up not all that worth it in the end? be on your way to having the money for a full management system. the small gains u make with the safc2 in the meantime probably arent that earth shattering that you couldnt have gone without them and saved for a bit longer?
it wouldn't cost more then around $100 to get an s-afc tuned, well worthwhile if you aren't looking at doing anything serious. The gains really depend on how bad the state of tune was previously, and how many mods you have done since. You should be able to see a nice 10-15rwkw increase in most of the rev range if you haven't had your car tuned before with abit of boost, full exhaust and an fmic for example.
off your topic, jaff, but how can you run 5psi when the factory wastegate spring doesn't open until about 7psi with a full exhaust?
Wouldn't the turbosmart then be, instead of bleeding pressure to fool the wastegate spring to get a higher boost, adding pressure (which is not possible) to open the wastegate earlier?? :confused:
The factory wastegate spring is 5psi in a S1 33 GTS25t...
FWIW my DIY bleeder when closed gives 5psi all the way thru the rev range... The factory 2 stage boost is disabled...
I have the standard dump, 3" front and 3" cat back...
Back on topic...
I have an SAFCII... Installation is relatively easy if you download the English manuals from the US Apexi site... If it appears that you are missing wires from the wiring loom, you are looking at the wiring harness from the wrong direction... I soldered all my connections rather that using the included crimps and taps... Just a bit more reliable that way IMO...
You will need to enter the settings for your car before the car will start once it is wired in... HW4 in, HW4 out, and 1/1 calculation...
Cant remap r33's, the ecu microprocessor and the rom chip that contains all the maps are on the same chip, only r32's and silvia's can be remaped.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
