Hi guys,
recently, I bought a 1999 Nissan Skyline GT-X and wanted to change the rego, XOB 444 (Yes, I'm tetraphobic but that's not the point). I then used the old plate on my mum's BMW (it's the extra long white Euro plates) and after I organised it with RTA i found out it didn't fit! What can I do? can I hand it on the spoiler with ropes?
can I screw them on somewhere else on the back bumper? I need a solution and fast!
The dimensions for the Euro plate is 110X520MM for front and back
What my car CAN fit is134X372MM on the back. I can hang the front plate somewhere else.
Edited by EdwardHeartsU
https://www.sau.com.au/forums/topic/392531-nsw-euro-plates-problem/
From Bunnings, buy some long "6M" size screws. (- these replace the existing screws)
Also buy metal tubular spacers that will fit over them.
Once you've attached the Euro plates the rear plate will extend out beyond the number plate light - but that's the risk you take. However, there hasn't been a police blitz on broken rear number plate lights for over a decade.
It'll be better to procure the plates "GTX.444" or similar.
lol... that's exactly what he DOESN'T want
I'll stick with that. What other solution is there?
...you mean the blitz?
I was answering to "fast" - not "legal"
LOL
tetraphobia is the fear of the number 4.
pretty sure GTX.444 is exactly what he doesn't want ;)
Yeah I don't know why people especially Asians have such a thing about "4"! I know that it has a similar pronunciation as "death" in Chinese.
I know what you're getting at now hehe
Stupid superstitions about the devil's number too.
a catholic priest in gympie once had 666 on his number plate. this was funny for more than just the obvious reason. it was on a honda HRV, which at the time had the devil in the ads, where i think they had 666-hrv as the number plate.
  • 3 months later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
