Hello all!
New to the SAU forums but I may have lurked here for quite some time..
So, I had some questions I was hoping some Victorians could help me with.
- Does anyone have any information regarding tall people and R34's? I'm 6'9 and have been searching around for some information regarding room issues but nothing really came up with a answer.
- If no to the first question does anyone know of a car yard that has any 5 Speed R34's in stock? I'd much rather go to a car yard and see whether or not I can make myself fit instead of finding someone doing a private sale. I'd just rather not waste someones time like that only to find out my "bigfootism" will stop me from pursueing the sale.
Thanks in advance!
https://www.sau.com.au/forums/topic/392705-looking-for-some-advice/
33 would probably be a far better option, it's a much larger car than all the other RB based Skylines. 4 doors all have higher roofs so unless you're set on a coupe they will probably be better for your height.
Thanks for the information fellas!
I kinda had my worries that I would struggle with room so I was planning to budget in buying a aftermarket seat with some side mount rails.. BUT the main problem would be getting it home in the first place to even mount them up. Even then I'm not 100% sure that would work out in terms of being comfortable.
Also if anyone else has suggestions on cars I may yet have thought of would be great. (p.s. I don't fit comfortably in almost anything =P )
If you want, you are more welcome to try my R34, it's got super low rails with a Bride Low Max lol.
You might possibly fit height wise, but you probably wont fit into the seat haha, I'm 60kg and it hugs me just fine...
Thanks for the offer Charles I may take you up on that... Found a car to look at on Sunday after work so fingers crossed I can figure something out with the stock seat :)
p.s. your 34 looks awesome!
Cheers man :)
Yeah, no worries, just lemme know.
Charles do you use a cushion or something to see over the dash if you have low-rails?
Of course not, I just squat on my seat......
LOL nah, I can just somehow see over my dash just fine....
Part 2.
- What major items should I be looking at in a R34 for signs of abuse?
- Does anyone have any suggestions for a comfortable aftermarket seat? Ideally ADR approved. Have been looking at Sparco / Velo so far.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
