http://www.initialdrift.com.au/
Depends on things, but I assume you have a CAMS L2NS and a Wakefield licence, so $170 for non members I think mate :) Would be great if end up entering, would be great to get some pointers about car setup etc from another R31 owner.
Minispool (LSD, I think KAAZ only make them, if you can afford it)
Clutch (Be careful what you choose)
S13 Lower Control arms
2nd hand spring and good shock combo
That's probably what I would do for a cheap R31 setup.
Later with more money add Coilovers, castor arms, hydro handbrake.
Even later on a RB25DET conversion. RB30ET in my opinion is not worth it compared to the cost of a RB25 these days. Don't worry about big builds/power unless you want to compete in Australia. A stock engine has enough power with the usual mods.
If you want pointers on your drifting, or just something to start practising let me know. I'm still learning but I did receive what I consider bad advice when I was starting off.
  • Replies 55
Posted Images
Thanks for the reply mate.
I rebuilt the diff with auto gears (3.9) and a minispool
I have S13 front LCA's, hubs, knuckles and brakes (I have R32 brakes on the way, too)
S13 HSD HR Coilover 8kg/mm front 7kg/mm rear, I also had some top hat adapters made by a machine shop so I didn't have to redrill the top hat
Adjustable panhard rod
I have everything except an intercooler for an RB30E+T setup, I have gotten all the parts pretty cheap but perhaps an engine conversion would have been a better plan - at least now I know
The interior has been completely stripped back to bare metal, battery into boot and inside painted
Aircon gear removed, other bits and pieces removed to save weight where ever possible
After the turbo setup goes on (this month) I will start saving for a new clutch, but I have heard a lot of different opinions so I'm a bit unsure here.
Cheers,
Anthony.
What pipes? Ebay cheapies suck. I have a set and they don't work or fit well. Just keep it standard unless you get a GTR setup.
I bought a brand new cooler just need to make up a kit for it I have heaps of pipes.. And btw stinkypoo it's Kyle I just sold my fd!! Woo so I'm focusing on finishing skyline now.. Was gunna run gtr cooler but this new one I got is pretty sweet!
  • 3 weeks later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
